ethereal
- Sep 10, 2012
hello i recently had a problem with long smart tests not being run as scheduled. so i was trying to solve the problem but got some mixed smart data back.
smartctl -a /dev/da0 | grep "progress" -i -A 1
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
as you can see 10% remaining but if i run
as you can see here all tests completed without error 0% remaining. this is happening on 6 discs out of 12 and as you can see there is no extended test run recently.
so which command to believe 10% remaing or 0% all completed ?
are there any commands to see what is what?
thank you
# 1  Short offline       Completed without error       00%     37810         -
# 2  Short offline       Completed without error       00%     37787         -
# 3  Short offline       Completed without error       00%     37763         -
# 4  Short offline       Completed without error       00%     37738         -
# 5  Short offline       Completed without error       00%     37714         -
# 6  Short offline       Completed without error       00%     37690         -
# 7  Short offline       Completed without error       00%     37671         -
# 8  Short offline       Completed without error       00%     37643         -
# 9  Short offline       Completed without error       00%     37618         -
#10  Short offline       Completed without error       00%     37594         -
#11  Short offline       Completed without error       00%     37572         -
#12  Short offline       Completed without error       00%     37546         -
#13  Short offline       Completed without error       00%     36899         -
#14  Short offline       Completed without error       00%     36875         -
#15  Short offline       Completed without error       00%     36852         -
#16  Extended offline    Completed without error       00%     36847         -
#17  Short offline       Completed without error       00%     36827         -
#18  Short offline       Completed without error       00%     36803         -
#19  Short offline       Completed without error       00%     36779         -
#20  Short offline       Completed without error       00%     36755         -
#21  Short offline       Completed without error       00%     36732         -    as you can see here all tests completed without error 0% remaining. this is happening on 6 discs out of 12 and as you can see there is no extended test run recently.
thank you
