Help Plex
Carlito53
Hello, I would like to know how to delete metadata history on plex. Because sometimes certain episode additions are not taken into account and other and I can remove the media to put it back to check it does not work I have to delete and reinstall the plugin. I know it's possible because I did it when I was using it on windows. Under windows it was located under% LOCALAPPDATA% Plex Media Server but under TrueNas I don't know how to do it. Thank you
Jailer
Not strong, but bad
It's called the Plex dance and it's a royal pain sometimes.
