Help on topology
So the hardware is in place and I now have proper NAS server.
Chassis: Supermicro CSE846TQ-R900 (24 bay hotswap)
Mainboard: Supermicro X8DTE
CPU: 2x Xeon x5560
RAM :48GB ECC Registered DDR3
HD Controller: 3 x Dell H310 flashed to IT mode
Nettwork: 2 x Intel® 82574L Gigabit Ethernet Controllers
I have at hand 8 x 3 TB disks. 1 x 2 TB. 2 x 500 GB. 2 x 320 GB.
The initial idea was to take 4 x 3 TB and make a Vdev then move over some files and make another Vdev of the remaining 4 x 3 TB. Both running Raid5 / z1.
But since I now have 24 hot swap ports I have much more place to play with. So now I am wondering if i should run 2 and 2 disks in mirror instead, I will lose some space, but also have much better reliability. And it will be much easier to extend into the future by either adding or replacing 2 and 2 disks. In theory having 24 x 3 TB in mirror will give me 36 TB of data which is 3 times what I had and much more than I will ever need in my mind. And taking the future into account with both 4, 6, 8 and even bigger disks in future this will also increase
But what I have not been able to understand from the documents are if there is any problems with this setup when combining a Vdev of 2 x 3 TB with another Vdev of 2 x 320 GB. Will there be any performance issue here? Or will this be all ok?
A second maybe of-topic question is if there is a need or even possibility to run 2 Nics in FreeNAS?
What do you recommend here?
depasseg
FreeNAS Replicant
ZFS will stripe across all vdevs and do it's best to use the best performing vdev(s). It depends on your workloads, but I would be comfortable with using mirrors of different sizes.
Yes, you can run 2 NICs, but it's complicated. They can't be configured in the same subnet, and if you plan to use a LAG, then you should have at least more than 5 clients that are accessing it in order to see any benefit.
Would a Vdev with 2 older disks that has 300mb/s limit slow down the whole pool when the rest is 600mb/s or would it just be slow on some parts? In general several vdevs with mirror will that speed up the pool compared to raidz etc?
Robert Trevellyan
Pony Wrangler
A pool with two mirrors with variable performance will still perform better than a pool with a single mirror.
In general, the more vdevs you have, the better the IOPS, but streaming performance is less straightforward - my understanding is that reads like more disks, writes like simpler structure.
Chances are, whatever you build will be fast enough for home use, unless you do something pathological.
Ok great, cause i have space for 24 disks and I will be adding two and two disks in mirror. That way I have redundancy. And it I will also only have to buy 2 disks when needing more space. In theory it will give me more space than I will need the next 10 years...
Sent fra min E6853 via Tapatalk
Mr_N
If you going to do mirrored vdev's forget using anything but the 3TB drives, and when you need more space the best price point will be 4tb or higher drives :)
Why should I forgot that? So using 2x2TB in one vdev and 2x320gb on another is that so bad?
