Help!!! - Loading /Boot/defaults/loader.conf
Jude
Hi all (My apologies if this is in the wrong section)
About a month ago I bought a HP micro Server and following the step by step video tutorials and loaded Freenas. I then proceeded to load all my media onto the freenas machine, All was working perfectly.
Until last night, I came home and couldn't see the server, not even throught my browser. I plugged my screen into the server and rebooted the machine several times (freenas was loaded onto a USB stick) it starts to run but then gets stuck at this point
FreeBSD/x86 Bootstrap Loader, Revision 1.1
(root@build.ixsystems.com, Wed Apr 3 15:39:85 PDT 2013
The biggest issue, is I have no idea what i'm doing as I am not an I.T. person and although I have found similar issues on google, the answers are all way above my head.
I need help, but dumbed down so I can understand. I really don't want to reload and lose all my already saved media
interpeix
mmmm maybe your USB stick is broken, try to install freenas again into another USB stick and boot.
Jude
Thanks so much Interpeix, loaded onto new memory stick last night and worked like a charm
problem is it only imported 1 of the 3 volumes successfully, the other 2 are showing errors saying that it cannot read successfully. I have data on the one that I really don't want to lose.
any idea what I can do?
Jude
Do you have the errors?
I Hope this makes sense to you, cause I am lost
Request Method:​
GET
Request URL:​
http://10.0.0.8/storage/mountpoint/permission/mnt/TV Shows/
Software Version:​
FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
Exception Type:​
OSError
Exception Value:​
Invalid mountpoint /mnt/TV Shows
Exception Location:​
/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py in mp_get_owner, line 2230
Server time:​
Thu, 27 Jun 2013 09:40:57 -0700
Traceback
Environment:
Software Version: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
Request Method: GET
Request URL: http://10.0.0.8/storage/mountpoint/permission/mnt/TV Shows/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
105. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
166. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
20. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in mp_permission
573. form = forms.MountPointAccessForm(initial={'path': path})
File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in __init__
1194. user, group = notifier().mp_get_owner(path)
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in mp_get_owner
2230. raise OSError('Invalid mountpoint %s' % (path, ))
Exception Type: OSError at /storage/mountpoint/permission/mnt/TV Shows/
Exception Value: Invalid mountpoint /mnt/TV Shows
