pcloadetter
- Aug 15, 2015
I have a shell script I wrote which calls curl. I have curl installed in a jail, but I wanted to install it on the FN OS. (my script isnt related to anything jailed)
I attempt to install curl
which ends up with
I tried to install
I tried to call it from a jail
Any suggestions how I can use curl other than from within the existing jail
[root@xxx~]# pkg install curl-7.38.0_1
which ends up with
pkg: archive_read_open_filename(/usr/ports/packages/All/gcc-ecj-4.5.txz): Failed to open '/usr/ports/packages/All/gcc-ecj-4.5.txz'
I tried to install
with the same resultpkg install gcc-ec
and got the message/mnt/xxxx/jails/sabnzbd_1/usr/local/bin/curl
Shared object "libcurl.so.4" not found, required by "curl"
