Hi all,
please help, i installed nextcloud in freenas , using this video tutorial :
www.youtube.com
but there's a little different, after install finished, they go to management which there's some field about :
1. Data folder
2. Configure database
But i'm not find it when installing nextcloud on my freenas,
and after finished, i check this nextcloud is running well, but there's some warning like below :
There are some warnings regarding your setup.
Please help .
Thank you verymuch.
Regards,
How to Setup NextCloud on FreeNAS 11.2
Amazon Affiliate Store➡️ https://www.amazon.com/shop/lawrencesystemspcpickupGear we used on Kit (affiliate Links)➡️ https://kit.co/lawrencesystemsTry ITProTV...
1. Data folder
- PHP does not seem to be setup properly to query system environment variables. The test with getenv("PATH") only returns an empty response. Please check the installation documentation ↗ for PHP configuration notes and the PHP configuration of your server, especially when using php-fpm.
- Some app directories are owned by a different user than the web server one. This may be the case if apps have been installed manually. Check the permissions of the following app directories:
- /usr/local/www/nextcloud/apps-pkg/accessibility
- /usr/local/www/nextcloud/apps-pkg/activity
- /usr/local/www/nextcloud/apps-pkg/admin_audit
- /usr/local/www/nextcloud/apps-pkg/cloud_federation_api
- /usr/local/www/nextcloud/apps-pkg/comments
- /usr/local/www/nextcloud/apps-pkg/dav
- /usr/local/www/nextcloud/apps-pkg/encryption
- /usr/local/www/nextcloud/apps-pkg/federatedfilesharing
- /usr/local/www/nextcloud/apps-pkg/federation
- /usr/local/www/nextcloud/apps-pkg/files
- /usr/local/www/nextcloud/apps-pkg/files_external
- /usr/local/www/nextcloud/apps-pkg/files_pdfviewer
- /usr/local/www/nextcloud/apps-pkg/files_rightclick
- /usr/local/www/nextcloud/apps-pkg/files_sharing
- /usr/local/www/nextcloud/apps-pkg/files_trashbin
- /usr/local/www/nextcloud/apps-pkg/files_versions
- /usr/local/www/nextcloud/apps-pkg/files_videoplayer
- /usr/local/www/nextcloud/apps-pkg/firstrunwizard
- /usr/local/www/nextcloud/apps-pkg/gallery
- /usr/local/www/nextcloud/apps-pkg/logreader
- /usr/local/www/nextcloud/apps-pkg/lookup_server_connector
- /usr/local/www/nextcloud/apps-pkg/nextcloud_announcements
- /usr/local/www/nextcloud/apps-pkg/notifications
- /usr/local/www/nextcloud/apps-pkg/oauth2
- /usr/local/www/nextcloud/apps-pkg/password_policy
- /usr/local/www/nextcloud/apps-pkg/privacy
- /usr/local/www/nextcloud/apps-pkg/provisioning_api
- /usr/local/www/nextcloud/apps-pkg/recommendations
- /usr/local/www/nextcloud/apps-pkg/serverinfo
- /usr/local/www/nextcloud/apps-pkg/sharebymail
- /usr/local/www/nextcloud/apps-pkg/support
- /usr/local/www/nextcloud/apps-pkg/survey_client
- /usr/local/www/nextcloud/apps-pkg/systemtags
- /usr/local/www/nextcloud/apps-pkg/text
- /usr/local/www/nextcloud/apps-pkg/theming
- /usr/local/www/nextcloud/apps-pkg/twofactor_backupcodes
- /usr/local/www/nextcloud/apps-pkg/updatenotification
- /usr/local/www/nextcloud/apps-pkg/user_ldap
- /usr/local/www/nextcloud/apps-pkg/viewer
- /usr/local/www/nextcloud/apps-pkg/workflowengine
Please help .
Thank you verymuch.
Regards,
