Hey all - Total Linux noob here. I spent an hour or so search for a a solution to this, but anything I found was above my head. Hoping someone can take pity on me here.
My old media server kicked the bucket so I decided to give TrueNAS a try on my rebuild. So far, the learning curve has been high, but rewarding.
Here is my problem: I am trying to extract huge ZIP files between pools, and the only way I know how is to use Windows shares to extract between them. This is brutally slow - like 9-10 hours per file.
I have 2 pools created. Storage (14TB) which is made up of 5x 4TB drives and TEMP (2.5 TB) which is made up of 7x 500GB drives.
I am downloading 500 GB chunks from Backblaze (18 more to go!) after my last server kicked the bucket to the TEMP pool. I would like to extract the files using SHELL commands to the STORAGE pool.
I literally don't even know where to start, I'm afraid. I read something about installing 7zip into a jail, but then it went over my head.
Thanks in advance.
Thanks in advance.
