Help: Data Corruption, now what??
esamett
I had some loose cabling after I "borrowed" my CPU to diagnose a friend's computer failure. This generated a daily output message of "Degradation." [Daily Output 1 - Degradation]
My Freenas server was not shut down as I had thought when I fixed the cabling. Now I have a "Data Corruption error" [Daily Output 2 - Corruption]
I did a scrub. and the GUI says that I am on line. CLI: ZPOOL STATUS gives an error message. What else do I need to do? How do I identify corrupted files and remove error messages?
Thank you.
  • Daily Output 1 - degradation.txt
  • Daily Output 2 - corruption.txt
William Grzybowski
Do a zpool clear pool, then zpool scrub pool
If everything looks fine after that you're good to go
esamett
I did several cycles of scrub/clear and still have this message in daily output:
Checking status of zfs pools:
pool: video
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scrub: scrub in progress for 4h17m, 36.98% done, 7h18m to go
NAME STATE READ WRITE CKSUM
video ONLINE 0 0 0
raidz2 ONLINE 0 0 0
gpt/disk0 ONLINE 0 0 0
gpt/disk1 ONLINE 0 0 0
gpt/disk2 ONLINE 0 0 0
gpt/disk3 ONLINE 0 0 0
gpt/disk4 ONLINE 0 0 0
gpt/disk5 ONLINE 0 0 0
gpt/disk6 ONLINE 0 0 0
gpt/disk7 ONLINE 0 0 0
gptid/22b175d2-8e5a-11e0-b823-0021978fb278 ONLINE 0 0 15 15K repaired
gpt/disk9 ONLINE 0 0 9 9K repaired
After scrub finished the "repaired numbers" increased to 42K and 33K resptectively.
What is going on and what do I need to do?
ProtoSD
This is what I might try. Since you have raidz2, you can loose 2 disks and still be safe.
Lookup the serial numbers of the drives in the GUI.
Shut down remove ONE of the disks that match the serial # you got above.
Run some surface scan on it with a good disk tool, see if it passes.
Wipe it completely.
Put it back in
Boot up and tell the GUI to replace it, let it resilver.
See if there are still errors reported for that disk.
If not, repeat and do the same for the other.
You may need to think about replacing 1 or 2 disks, but don't use the array until all the disks are in it and it's resilvered. In theory that should be ok, but if it were me I wouldn't change anything until you eliminate the problem.
If you really want to be safe and have more time/disks etc., back it up first, but you have Z2, so if you are careful you should be fine. You also might try some different cables and do another scrub first....
