HELP !!! CRITICAL: The volume datastore (ZFS) state is UNKNOWN:
dan101aba
I need your help to understand how to restore my files from zfs missing device error,
I have the freenas load from USB version 9.3 with
3 SATA 4T (WD)
1 SSD 250gg
Since I got a Unretryable error on boot I try to reinstall a new version on USB, but my mistake I did it on the SSD drive.
After I did install on USB and upload my config files I got below error.
Not sure what was my ZFS configuration and if the SSD(may be cache ) was part of the pool.
I would like to know if there is an option to restore the files from the 3 STATA disks?
See below some command I run to bring up the pool
pool: datastore
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see: http://illumos.org/msg/ZFS-8000-EY
datastore UNAVAIL missing device
raidz1-1 ONLINE
gptid/54f3c43f-efd7-11e3-989a-e03f49ac0a05 ONLINE
gptid/55be4974-efd7-11e3-989a-e03f49ac0a05 ONLINE
gptid/568b922e-efd7-11e3-989a-e03f49ac0a05 ONLINE
pool: freenas-boot
state: ONLINE
status: The pool is formatted using a legacy on-disk version.
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
freenas-boot ONLINE
ada0p2 ONLINE
[root@freenas] /mnt# zpool import -f datastore (also import -F -f datastore)
cannot import 'datastore': one or more devices is currently unavailable
[root@freenas] /mnt# glabel status
Name Status Components
gptid/f40c5b80-b67f-11e8-85f0-e03f49ac0a05 N/A ada0p1
gptid/f40d520f-b67f-11e8-85f0-e03f49ac0a05 N/A ada0p2
gptid/54e46e1b-efd7-11e3-989a-e03f49ac0a05 N/A ada1p1
gptid/54f3c43f-efd7-11e3-989a-e03f49ac0a05 N/A ada1p2
gptid/55af7227-efd7-11e3-989a-e03f49ac0a05 N/A ada2p1
gptid/55be4974-efd7-11e3-989a-e03f49ac0a05 N/A ada2p2
gptid/5679804c-efd7-11e3-989a-e03f49ac0a05 N/A ada3p1
gptid/568b922e-efd7-11e3-989a-e03f49ac0a05 N/A ada3p2
gptid/7988e498-b9a7-11e8-bb6c-e03f49ac0a05 N/A da0p1
[root@freenas] /mnt# gpart show
=> 34 468862061 ada0 GPT (223G)
34 1024 1 bios-boot (512k)
1058 6 - free - (3.0k)
1064 468861024 2 freebsd-zfs (223G)
468862088 7 - free - (3.5k)
=> 34 7814037101 ada1 GPT (3.7T)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 7809842696 2 freebsd-zfs (3.7T)
7814037128 7 - free - (3.5k)
=> 34 7814037101 ada2 GPT (3.7T)
=> 34 7814037101 ada3 GPT (3.7T)
=> 34 61194173 da0 GPT (29G)
1064 61193136 2 freebsd-zfs (29G)
61194200 7 - free - (3.5k)
also see attach file run smartctl - q on all disks
Thanks for any help
Dan
  • smartctl-q-noserial.txt
kdragon75
Protip #1 When installing FreeNAS, disconnect your data drives to avoid overwriting data.
Ok so you had a RAIDz1 and destroyed one disk. You SHOULD be ok. Install the latest BETA as it has better support for importing damaged pools. (See Protip #1)
Once you have a running version of FreeNAS 11.2 BETA3, you should be able to import your pool. If it offers to "upgrade" your pool, dont. Just import it. If the pool still does not show up in the GUI after a successful import, reboot.
If the pool is showing up in the GUI, follow the user guide for the beta to replace a failed drive. If you are unsure or anything is not 100% clear, STOP and ask. Any mis steps at this point and you data is lost.
Protip #2 Always keep backups separate from your main storage.
After the new/old drive is installed and your pool is done with the scrub, install a non-beta version of FreeNAS like 11.1-U4.
Protip #3 Dont run Beta software unless you can debug issues on your own or don't care if your data is lost. ;)
Chris Moore
If you would, take a moment and put all that text inside a code block like this:
pool: datastore
  state: UNAVAIL
	  raidz1-1									  ONLINE
   pool: freenas-boot
  state: ONLINE
	freenas-boot  ONLINE
	  ada0p2	ONLINE
Much easier to read.
dan101aba
Thanks for the help, I did FreeNAS 11.2 beta 3 installs, and also replace SSD with SATA 2T, and try run import from UI (without success no datastore pool listed) also failed from the command line
Please let me know if you have another idea how to resolve it?
root@freenas[~]# zpool import
pool: datastore
state: UNAVAIL
datastore UNAVAIL insufficient replicas
3359151836782873844 UNAVAIL cannot open
raidz1-1 ONLINE
root@freenas[~]# zpool import -f datastore
cannot import 'datastore': no such pool or dataset
Destroy and re-create the pool from
a backup source.
root@freenas[~]#
kdragon75
@dan101aba Use the code tages as requested.
Have you tried zpool import -F? Do you recall how the array was laid out? If it was a RAIDz1 and you have insufficient replicas, that means at least two disk are missing from the vdev. Did they fail? were you trying to replace old disks with larger ones? Did you throw the server on the ground? Tell us what happened.
Chris Moore
This is made more difficult to read because it is not in code tags, which affects the way the text aligns:
   pool: datastore
  state: UNAVAIL
	  raidz1-1									  ONLINE
	a backup source.
root@freenas[~]#
Now that it is properly displayed, you can see that the missing drive was a single disk vdev that is now missing. You must find that missing disk or this pool is destroyed. There is no recovery from this. The pool was not properly constructed.
Chris Moore
From OP's text file:
[root@freenas] /mnt# smartctl -q noserial -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p5 amd64] (local build)
Model Family:	 SandForce Driven SSDs
Device Model:	 KINGSTON SV300S37A240G
Firmware Version: 520ABBF0
User Capacity:	240,057,409,536 bytes [240 GB]
Sector Size:	  512 bytes logical/physical
Rotation Rate:	Solid State Device
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS, ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun Sep 16 17:22:58 2018 IDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)   Offline data collection activity
				   was never started.
Self-test execution status:	  (   1)   The previous self-test routine completed
				   been run.
data collection:		(	0) seconds.
capabilities:			 (0x79) SMART execute Offline immediate.
				   No Auto Offline data collection support.
				   command.
				   Self-test supported.
SMART capabilities:			(0x0003)   Saves SMART data before entering
				   power-saving mode.
Error logging capability:		(0x01)   Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 (  48) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x0025)   SCT Status supported.
				   SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x0033   120   120   050	Pre-fail  Always	   -	   0/0
  5 Retired_Block_Count	 0x0033   100   100   003	Pre-fail  Always	   -	   0
  9 Power_On_Hours_and_Msec 0x0032   058   058   000	Old_age   Always	   -	   37032h+12m+47.930s
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   51
171 Program_Fail_Count	  0x000a   000   000   000	Old_age   Always	   -	   0
172 Erase_Fail_Count		0x0032   000   000   000	Old_age   Always	   -	   0
174 Unexpect_Power_Loss_Ct  0x0030   000   000   000	Old_age   Offline	  -	   47
177 Wear_Range_Delta		0x0000   000   000   000	Old_age   Offline	  -	   3
181 Program_Fail_Count	  0x000a   000   000   000	Old_age   Always	   -	   0
182 Erase_Fail_Count		0x0032   000   000   000	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0012   022   022   000	Old_age   Always	   -	   78
189 Airflow_Temperature_Cel 0x0000   030   044   000	Old_age   Offline	  -	   30 (Min/Max 16/44)
194 Temperature_Celsius	 0x0022   030   044   000	Old_age   Always	   -	   30 (Min/Max 16/44)
195 ECC_Uncorr_Error_Count  0x001c   120   120   000	Old_age   Offline	  -	   0/0
196 Reallocated_Event_Count 0x0033   100   100   003	Pre-fail  Always	   -	   0
201 Unc_Soft_Read_Err_Rate  0x001c   120   120   000	Old_age   Offline	  -	   0/0
204 Soft_ECC_Correct_Rate   0x001c   120   120   000	Old_age   Offline	  -	   0/0
230 Life_Curve_Status	   0x0013   100   100   000	Pre-fail  Always	   -	   100
231 SSD_Life_Left		   0x0013   095   095   010	Pre-fail  Always	   -	   0
233 SandForce_Internal	  0x0032   000   000   000	Old_age   Always	   -	   47359
234 SandForce_Internal	  0x0032   000   000   000	Old_age   Always	   -	   32106
241 Lifetime_Writes_GiB	 0x0032   000   000   000	Old_age   Always	   -	   32106
242 Lifetime_Reads_GiB	  0x0032   000   000   000	Old_age   Always	   -	   21544
SMART Error Log not supported
SMART Self-test Log not supported
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] /mnt# smartctl -q noserial -a /dev/ada1
Model Family:	 Western Digital Red (AF)
Device Model:	 WDC WD40EFRX-68WT0N0
Firmware Version: 80.00A80
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
Local Time is:	Sun Sep 16 17:23:21 2018 IDT
				   was never started.
Self-test execution status:	  (   0)   The previous self-test routine completed
				   been run.
data collection:		(53160) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
				   command.
				   power-saving mode.
recommended polling time:	 ( 532) minutes.
recommended polling time:	 (   5) minutes.
SCT capabilities:		   (0x703d)   SCT Status supported.
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   182   176   021	Pre-fail  Always	   -	   7866
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   47
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   050   050   000	Old_age   Always	   -	   37109
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   47
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   32
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   832
194 Temperature_Celsius	 0x0022   120   104   000	Old_age   Always	   -	   32
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   100   253   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
oot@freenas] /mnt#
[root@freenas] /mnt# smartctl -q noserial -a /dev/ada2
Local Time is:	Sun Sep 16 17:23:40 2018 IDT
				   was never started.
				   been run.
data collection:		(51540) seconds.
				   command.
				   power-saving mode.
recommended polling time:	 ( 515) minutes.
  3 Spin_Up_Time			0x0027   181   174   021	Pre-fail  Always	   -	   7933
  9 Power_On_Hours		  0x0032   050   050   000	Old_age   Always	   -	   37110
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   822
194 Temperature_Celsius	 0x0022   122   105   000	Old_age   Always	   -	   30
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] /mnt# smartctl -q noserial -a /dev/ada3
Local Time is:	Sun Sep 16 17:23:54 2018 IDT
				   was never started.
				   been run.
data collection:		(51840) seconds.
				   command.
				   power-saving mode.
recommended polling time:	 ( 518) minutes.
  3 Spin_Up_Time			0x0027   181   175   021	Pre-fail  Always	   -	   7933
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   826
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
kdragon75
garm
Well based on the information given you destroyed the SSD that was part of the pool as a single drive vdev by installing FreeNAS on it. By doing that you made the pool unrecoverable, you need to rebuild your pool properly and restore from backup. Also, please use code tags..
