Miguel Nunes
- May 6, 2016
I am in the middle of completing the configuration of a web applications' server, but I am a bit lost on the storage solution. The Motherboard is a AsRockRack EP2C602 D16/4L and, since it doesn't like GPU passthrough that much, I decided to assign it to a develop, preproduction server.
The case has 24 hot swap bays, the board has 2xSATA III + 4xSATA 2 + Marvel 4xSATA3. I am planning to use XenServer (because ESXi free doesn't work with 2 x E5-2650 v1). Bought a SAS expander, late to find out that it doesn't interoperate with Dell's PERC 310. HP P410 was a possibility, till I read there are BIOS complications.
The question is: What would be the best for a Web Apps machine?
Possibility 1: 3 x PERC 310 to control the back plane in 3 x 8 drives blocks.
Possibility 2: Find a controller that supports the expander.
Possibilities 3..oo: Some other choice you find better.
I will be looking forward for your kind help.
Best Regards.
MAN
Best Regards.
MAN
