Contentt
 - Mar 7, 2013
Hoping for some ideas to help get up and running, never used Unix before and this is just a hobby for a non-techy.  Just installed FreeNas on 2GB USB stick and hooked it into an old Dell with two old 250GB drives, but I can't the GUI to come up. After install I get an IP of //0.0.0.0.  I looked at my router and it assigns it an IP of 192.168.1.10 using DHCP.  But after a few minutes the FreeNas box disappears from the list of computers on my network, screen has message "Watchdog timeout - resetting" after not selecting a 1-10 option. An address ping from my laptop to 192.168.1.10 get's no response.  I tried setting the IP manually for IPv4 using 192.168.1.10 and it doesn't show up on network and can't access GUI.  The box is connected directly into the router. Any suggestions would be appreciated, thanks.
Dave
			Dave
