Dubravko Vukmirovic
- Jun 20, 2015
Hi
After several hours of researching I decided to ask on forum.
zfs destroy -rv RAID10@auto-20150930.1700-2w
dataset is busy
! this is oldest file, any other files including latest says dataset is busy
Gui is saying 'Held by replication system'
! there is no replication configuration
From other research
From man of section 2 intro page the errors are listed. Number 16 looks to be an EBUSY.
EBUSY Device busy
An attempt was made to mount a device that was already mounted or an attempt was made to unmount a device on which there is an active file (open file, current directory, mounted-on file, active text segment). It will also occur if an attempt is made to enable accounting when it is already enabled. The device or resource is currently unavailable. EBUSY is also used by mutexes, semaphores, condition variables, and r/w locks, to indicate that a lock is held, and by the processor control function P_ONLINE.
What should I do next?
I have available storage but cannot put any files, stating out of space. I have 486 files X 389MB of snapshots
8 GB memory
FreeNAS-9.2.1.7-RELEASE-x64
4 x 2 GB hard drive
Thank you
Dubravko
dataset is busy
From other research
EBUSY Device busy
8 GB memory
4 x 2 GB hard drive
Thank you
Dubravko
