Dear community,
I am running FreeNAS for multiple years already without any major problems. Now just recently it appears to me that my USB Stick as well as my raid controller?! crashed at the same time. Maybe my power supply had a failure.
System setup: I am running an encrypted 0+1 RAID with 4x 4TB and the discs had no sign of SMART errors recently. I am booting from a Scandisc USB and was running the latest version of FreeNAS (not TrueNAS yet).
From one day to the other my network drives where not reachable any more and the system didn't respond to the UI any more. After restart I saw that there was no Raid Array configured for the raid controller (0 logical volumes). When I tried to run HP Smart Storage Administrator the system bar loads to 100% and then crashed with a Kernal panic: LZMA data is corrupt; Kernel panic: not syncing: VFS: Unable to mount; Pid 1 comm: Swapper Not tainted 3.0.76-0.11-default #1
Since I count create a logical volume with that machine, I decided to buy an identical server (HP Proliant Miniserver Gen 8) and identical drives.
At first I cloned all 4 HDDs to make sure I only work with the cloned copies to not risk any data loss.
Secondly I tried to restore the Raid Array with the new Server (and the cloned HDDs).
Once the Array was in created (via HP Smart Storage Administrator) I tried to boot via the old Scandisc Stick in the new Server. The system still cant boot even if I pick old Kernel versions. The bootup stops when the system was trying to mount the devices.
Next I installed a clean trueNAS on a new SSD and used that SSD for Bootup (BIOS settings to support legacy RAID). TrueNAS boots successfully and I can see the 4 discs in TrueNAS. Now I did a mistake, I guess - I tried to create new Pools using the Array with the 4 discs, which started a formating process.
So now I am creating new clones and I need to try to not create new pools but import existing ones. The problem is I have no settings backups or anything. Of course I have the HDD encryption password, but apparently I also need a "file" to import pools.
My questions:
- Any chance to import the pools without having done a backup accordingly?
- Any chance that I get the pool information from the SSD stick that I still have access to, but apparently it wont boot again?
PS: Sorry if some of the terminology is wrong. I am not super specialist but a self thought beginner.
Thanks for your support
My questions:
