Having trouble installing Ubuntu in a VM
PDizzz
After Ubuntu is finished installing, then what do I do to actually run Ubuntu?
Leaving the CD-ROM device in the VM will just boot to the iso file, and deleting the CD-ROM device results in booting to the UEFI shell. I know if you type "exit" in the shell you can change boot options, but everything appears in order.
I'm sure there's something simple I'm not doing.
D
dlavigne
Guest
Which build version of FreeNAS (from System -> Information)?
Spencer Skinner
Go to Boot Maintance in EFI then go to boot from file, then EFI, then debian, the grubx64.efi and hit enter. It will boot into Ubuntu then run these commands
sudo -i
mkdir /boot/efi/EFI/BOOT
cp /boot/efi/EFI/ubuntu/grubx64.efi /boot/efi/EFI/BOOT/bootx64.efi
Hope that helps
Phil Demand
sudo -i
Hope that helps
That worked great. Thank you.
