FREAKJAM
- Oct 10, 2013
For the last 6 weeks i'v been reading the internet after I decided that I want to renew my setup that I am currently using as my "NAS". Basically im running a HTPC, with XBMC on it and 2 harddrives, providing me with a total of 4TB of data. Im not running RAID or whatsoever. My current setup is like 3 years old and it actually works just fine, but as stated im running out of space.
I'm a system engineer and I work with Windows Servers and VMWare on a daily base. Combined with the "problem" as mentioned above I decided I want to build a new home server. I want to setup a ESXi server combined with FreeNAS running Plex Media Server and I want to use the home server to educate myself more and to play with VMWare. I'm aware of the fact that it's not adviced to run FreeNAS in a virtualized environment.
After 6 weeks of reading about ZFS (which is totally new to me), ESXi 5, FreeNAS, OpenMediaVault, ZFSGuru etc etc, I think it's time to make a choice, order my parts and setup my new server. Before ordering, I would like to post my current setup which I have in mind here, and ask u guys to critique my setup and maybe to give me some pointers. (Many people already assisted me on some dutch forums, but I also want you guys opinions). As stated, i'm totally new with ZFS & FreeNAS, so correct me when wrong if/when i'm making wrong statements.
CPU: Intel Xeon E3-1230V3
MOBO: Supermicro X10SL7-F
MEMORY: Kingston ValueRAM KVR16E11/8 (2x, thus providing me 16GB ECC unbuffered memory).
HDD: WD Red WD40EFRX, 4TB (3x)
SSD: Crucial 2.5" M500 120GB (2x, one as datastore for ESXi, the other for ZIL/L2ARC on the very same SSD).
PSU: Seasonic G-Serie 360watt
USB: Sandisk Extreme USB 3.0 Flash Drive
Setup explained:
CPU: cheapest Xeon CPU with hyperthreading. No GPU chipset included, but the SM board supports IPMI. Supports VT-d/VT-x and is based on the C222 chipset, so good to go for ESXi.
MOBO: Dual NIC, LSI 2308 onboard. NIC's might not be working with ESXi out the box, but we have a fix for that. ECC memory, best option for when running ZFS.
MEMORY: ECC Memory. I will probably only run FreeNAS with maybe pfSense for now, so 16GB will be just fine. I'm aware of the rule xTB equals xGB ram, and since I want to provide my home server with 12TB of data, 16GB will do. I will have 2 slots left in the SM board, so that I can upgrade in the future.
HDD: Not really sure bout these, but I think RED's are the best to go. Suitable for a 24/7 environment and a fair price. Wanted to use Seagate Desktop HDD.15 ST4000DM000 drives at first in my setup, but someone on newegg stated that the drives do not always work with LSI-cards:
If anyone thinks I should use other drives, please tell me so.
SSD: has power-safe capacitors, so ideal for ZIL.
USB: supports very good random write speeds, ideal USB-stick to run a OS from. (ESXi boot).
I'm aware that running 3 disks of 4TB is not the best/safest option. I want to run RAIDZ. My case is a Bitfenix Phenom Micro ATX, so i'm not able to stuff the case with tons of hard disks. (Phenom Micro-ATX can be outfitted with up to five 3.5" HDDs or six 2.5" SSDs.). I will not be storing critical data on the NAS, most of it will be media, so running everything in a RAIDZ setup (meaning that if 2 disks will fail I will loose everything, is a risk i'm willing to take).
I will keep my old HTPC and I will remove the 2x2TB hard drives. A new SSD will be placed in the HTPC. Will be running Windows + Plex Client. (So basically I want to stream the media from the NAS to my HTPC). Maybe I can reuse the 2x2TB (Samsung Spinpoint F4 EG HD204UI, 2TB) drives in some way in my new setup? When going for a 3x4TB setup, i will have room left for 2 more HDD. I maybe can use the old 2tb drive to save ESXi snapshots.
questions:
1) Critique my setup (keep in mind that I am new to FreeNAS, ZFS etc, so please be gentle :))
2) If 3x4tb in RAIDZ is really not the way to go, what setup should i use? Maybe4x4TB in RAIDZ2? Again, I wont be storing critical data on my drives. (still, nobody wants to lose data).
3) How many NICS would I actually need for my setup? Two is just fine right?
4) Reading mixed stories bout running ZIL/L2ARC on the same SSD. Is it safe to run ZIL/L2ARC on the same SSD?
5) is 360 watts psu power enough for this setup?
Thanks in advance.
Setup explained:
This drive does not work with some controller cards! When connected to LSI host bus adapters and connected to LSI backplanes the drive will not spin up. Additionally the bay that the drive was inserted into is permanently disabled until the entire computer is powered off and cold-booted!
This is a hardware/firmware flaw either in one of:
* LSI SAS9207-8i (contains an LSISAS2308 controller)
* Supermicro BPN-SAS-826EL2 (contains an LSI SASX28 expander)
* Seagate ST4000DM000
LSI refuses to address the problem since this drive is a "desktop" drive. That's stupid because the drive is in my _desktop_ -- not a server! Seagate has clearly done something different to this drive since their "enterprise" class drives work just fine -- and cost double the price of this one. I'm not even using RAID.
This drive model is defective and I will not be purchasing any more unless either Seagate or LSI provide me with a working firmware to fix this problem. I tested 6 different drives with two different firmwares, from two different stores, manufactuered in two different countries on two different controller cards. This is a design flaw!
questions:
Thanks in advance.
