Hi, I'm building anther FreeNAS box. System is going to be used for an iSCSI target to my WMC server as recording storage. It will also serve as iSCSI targets to other HyperV lab servers and CIFS shares. I'm having a hard time deciding which direction to go Xeon V2 or V3. It will eventually house around 48TB total, 24x 2TB drives. (3 x RAIDZ2 vdevs 8drives).
I've looked at the supermicro MBD-X10SRL-F with 4x16GB (64GB) DDR4 ECC RDIMMs and a Xeon E5 2620V3.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182927
http://ark.intel.com/products/83352/Intel-Xeon-Processor-E5-2620-v3-15M-Cache-2_40-GHz
I could save some money going with a Xeon V2 system and a used CPU on ebay, but is that money saved really worth it in the long run vs spending a little more now and having it last longer? I also don't want to be limited to a 32GB memory board which leaves no expansion if I ever went with bigger drives.
Other question is the memory. If I go with DDR4, I originally only wanted to start out with 2x 16GB RDIMMs, but not sure if this will cut performance in half only utilizing 1 memory channel vs if I went with say 4DIMMs upfront whether it be 4x8GB or 4x16GB.
Any reasonable opinions always welcome.
Thanks,
Thanks,
