Hi
I'm having an issue with the BIOS recognizing my drives. I have 6 x 4TB Seagate NAS drives and none are detected when plugging into the backplane of the Norco RPC-3216. The backplane is Fuhe BP-001c and supports sas and sata drives. However I'v head no luck with the SAS controller or SATA controller when using the backplane. However, when I use a strait SATA cable, the board sees the drives. There is power to the drive, or at least I see a light. I've tied other drive sizes with no success. My question is, which is the most likely candidate for the problem, the main board, backplane or cables? Are they not compatible? I've tried several of the HighPoint cables any no luck.
Board: Supermicro X10SL7-F
Chasis: Norco RPC-3216
Cables: HightPoint Internal mini-SAS to 4SATA (SFF8087 to SATA) INT-MS-1M4S
Thanks for any help.
Peter
Peter
