Why would you arrive at that conclusion? Their quoted error rates are identical, apart from deceptive advertising.
My apologies. I was thinking about one hard drive model and wrote about another. I will edit my erroneous misleading post.
In my mind, I was comparing model WD60EFRX (WD Red™) against WD6001FXYZ (WD
Re™), and not against WD6001FFWX (WD Red
Pro™),
for an at-home-NAS.
The PDFs with relevant information are
Red http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-800002.pdf , non-recoverable read error rate per bits read (URE rate) < 1 in 10^
14, MTBF
1000000h
Red Pro http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-800022.pdf , (URE rate) < 10 in 10^15 = 1 in 10^
14, MTBF
1000000h
Re http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-800066.pdf , (URE rate) < 1 in 10^
15, MTBF
2000000h
Background story. As a family, we commit lots of GBs into our appliance-based at-home-network-storage. It started almost a decade ago with D-Link DNS-323, using mirrored drives at a capacity that I do not recall, but upgraded to 2 x 1.5 TB (in RAID-1) as soon as 1.5 TB drives from Seagate were available in 2008. Rewind to FreeNAS 8.0.2. It seemed like a good idea at the time to use WD Black drives, the best idea ever... They delivered the performance and at the time allowed to look at the AF (Advanced Format) transition from the sidelines, but the noise and temperature issues did not make WD Black drives good tenants in our living room. Toyed with WD Greens, however WD started advertising that for NAS, we should use drives designed for NAS...
Thus WD Reds became my favourites. Today, for us, both WD Red Pro and WD Re are too noisy and too power hungry (as WD Blacks are). I had carefully looked at the warranty, AFR (MTBF) and non-recoverable read errors per bits read for WD Re. However, at almost a double of power dissipated as compared to WD Red, to me they are only a living proof that Western Digital can make drives with better parameters.
When would I recommend
Re or
Pro models? If the network connection is better than a single Gigabit Ethernet. If there are two pools in the server and there are copies being done between them on the server itself. If there is some disk intensive processing being run on the server etc. And, at the same time, heat and noise are not the limiting factors. Then one should consider those ($$$$) models.
Re and
Pro models also give a benefit of faster scrubs and faster disk replacement. And most importantly, deploying WD Re gives one a 10 disk RAID-Z2 with probability of a failure that is less than 10 disk RAID-Z3 with WD Red or WD Red Pro.
P.S.
When we were buying WD Green drives model WD15EADS, they were being sold with a 3 year warranty, and in their specs URE rate was
1 in 10^15. Nowadays, finding a PDF with the original WD15EADS specification on the Western Digital site is next to impossible...
