smit4.hage4
- Apr 23, 2016
I'm half way through building a new FreeNAS box. I've bought a Supermicro SC846BE16 - which I intend to partially fill with an IBM M1015. The main point here is that I'm tired of buying 4 bay units and not having any room to grow (also wanted 4U regardless). I will purchase more disks down the track when I can afford to.
I currently have 8.8Tib of data and would like some recommendations on drives. Workload will mostly be reading TV shows, movies and writing weekly backups. I can split my data into two pools if that provides a better outcome.
Data on failure rates often seems to be anecdotal. So useful advice would be from anyone with 8+ drive configurations. Some forums strongly suggest that vibrations will be the end of any drive unless you buy enterprise class drives. Is this accurate? Can I space the drives out?
I was considering 8x 4TB drives and installing 6 now in a Raidz2. But open to suggestions.
Can anyone comment on WD Reds vs WD Red Pro?
I've read that data from Backblaze is not representative as the sample size is too small in some cases. It also suggests that Seagate's failure rates have improved drastically. If anyone has recent experience running a large Seagate box with drives purchased in the last 2 years I would be interested to hear. (Yes I understand that 2 years is not a big enough sample but this is more useful that hearing about drives no longer available for sale.)
Cheers
Cheers
