Hard Drive Alert
Mudd
Hi:
I am running FreeNAS 9.10, I have 6 3T WD Red drives. I am getting the alert shown below. I wanted to run S.M.A.R.T test using SSH from the GUI. When I select Shell from the GUI and type: smartctl -t /dev/ada5 and I hit "enter" I do not get a response. I could run it from "Task", but I only want to run it once. How do I do it?
CRITICAL:					 April 27, 2018, 11:01 a.m. - Device: /dev/ada5, 8 Currently unreadable (pending) sectors
CRITICAL:					 April 27, 2018, 11:01 a.m. - Device: /dev/ada5, 8 Offline uncorrectable sectors
Thank you.
PhilipS
For the short test you would run smartctl -t short /dev/ada5 for the long smartctl -t long /dev/ada5
PhilipS
Also if you run smartctl -a /dev/ada5 and post the output, some smart people on here can give you better advice.
I only wan to run it once.
You should be running regular short and long SMART tests as a matter of course anyway.
Mudd
Shell
[root@freenas ~]# smartctl -t short /dev/ada5
This is a copy of my screen. When I hit enter on the keyboard, nothing happens.
PhilipS
The command returns immediately and the test runs in the background - to check the result run smartctl -a /dev/ada5 will show the test results near the bottom or smartctl -l selftest /dev/ada5 for just the test results.
Nothing except that you return to the shell prompt, right? That's exactly as expected. Somebody ought to write a resource about this subject.
Mudd
Here is the data:
Model Family:	 Seagate Barracuda 7200.14 (AF)
Device Model:	 ST3000DM001-1CH166
Serial Number:	Z1F3Z8XD
LU WWN Device Id: 5 000c50 0651a3e14
Firmware Version: CC27
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Fri Apr 27 14:43:42 2018 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
										was completed without error.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(  575) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   1) minutes.
Extended self-test routine
recommended polling time:		( 317) minutes.
Conveyance self-test routine
recommended polling time:		(   2) minutes.
SCT capabilities:			  (0x3085) SCT Status supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   118   099   006	Pre-fail  Always	   -	   176670256
  3 Spin_Up_Time			0x0003   095   093   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   144
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   064   055   030	Pre-fail  Always	   -	   55869401650
  9 Power_On_Hours		  0x0032   068   068   000	Old_age   Always	   -	   28610
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   143
183 Runtime_Bad_Block	   0x0032   099   099   000	Old_age   Always	   -	   1
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0 0 0
189 High_Fly_Writes		 0x003a   099   099   000	Old_age   Always	   -	   1
190 Airflow_Temperature_Cel 0x0022   070   048   045	Old_age   Always	   -	   30 (Min/Max 29/31)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   91
193 Load_Cycle_Count		0x0032   098   098   000	Old_age   Always	   -	   5145
194 Temperature_Celsius	 0x0022   030   052   000	Old_age   Always	   -	   30 (0 18 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   8
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   8
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   27906h+42m+17.118s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   17372956743
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   49547836209
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 28610		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
PhilipS
Being a Seagate ST3000DM, I would replace the drive - it will most likely fail soon.
Jailer
Not strong, but bad
Run a long test as well and post the output in code tags.
