GUI saying one thing... zpool says another.
Robin Ball
Hi folks,
I have an odd one for you. My GUI is saying there is a problem with one of my disks... zpool does not. Anyone come across this before?
Cheers, Rob
ZPOOL STATUS OUTPUT:
pool: ZFS16
state: ONLINE
scan: scrub repaired 0 in 20h1m with 0 errors on Sun Nov 12 20:01:05 2017
NAME STATE READ WRITE CKSUM
ZFS16 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/4f23162a-eb4e-11e4-afc8-e03f490de638 ONLINE 0 0 0
gptid/500a51ef-eb4e-11e4-afc8-e03f490de638 ONLINE 0 0 0
gptid/5070e197-eb4e-11e4-afc8-e03f490de638 ONLINE 0 0 0
gptid/50cea95c-eb4e-11e4-afc8-e03f490de638 ONLINE 0 0 0
errors: No known data errors
GUI ERROR:
  • CRITICAL: Nov. 25, 2017, 8:20 p.m. - Device: /dev/ada1, 1 Currently unreadable (pending) sectors
  • CRITICAL: Nov. 25, 2017, 8:50 p.m. - Device: /dev/ada1, Self-Test Log error count increased from 0 to 1
garm
That is a S.M.A.R.T error and not a ZFS error.
I would replace the drive and then run a long test etc on a different machine
rs225
That is normal. The error isn't going to show up with ZFS; it is the SMART monitoring letting you know that there is a marginal sector that the drive will attempt to relocate the next time it is written. You can ignore it, attempt to force relocate it, or replace the drive. I would recommend doing nothing, but keep an eye for any further changes in error count.
Jailer
Not strong, but bad
Is the drive under warranty? If so RMA it.
Jailer
Not strong, but bad
Keep an eye on it then and if the errors increase replace it.
