markymark832
- Feb 28, 2017
thanks for the reply, i'm just using the .xml file for the connection setting for now, i don't really need the sql implentation,Did you try a static configuration first, that's what I did. Then switched to MySQL after everything worked. I cannot remember that I installed anything special, the guacamole package simply pulled in all the necessary dependencies.
The docs for static configuration can be found here:
For reference, my guacamole config is rather unspectacular:
Code:# guacgd.conf [daemon] [server] bind_host = localhost bind_port = 4822 # guacamole.properties uacd-host: localhost guacd-port: 4822 mysql-hostname: localhost mysql-port: 3306 mysql-database: guacamole mysql-username: guacamole mysql-password: ********* mysql-user-required: true
Plus you need to manually putguacamole-auth-jdbc-mysql-1.0.0.jarinto/usr/local/etc/guacamole-client/extensions.
HTH,
Patrick
i'll bin the jail and start again, but this time output the results on the pkg install to see if it is pulling the dependencies
fingers crossed
