I've been a longtime user of FreeBSD and for a while I did run FreeNAS 0.7x but I had a shoddy hardware platform back then and it stopped working years ago. I'm ready to dive in again, so I am building a box to host lots of audio and video media, plex transcodes, backups to amazon, nfs or iscsi mounts for use by ESXi, backups from client PCs (time machine backups for two macbook pros and a few others boxes in the house) and also several other jailed apps like an freeradius, nginx reverse proxy, webapp containers like tomcat, node.js, an hsqldb database, gitlab, jenkins, etc.
I did review the "read this first" advice on hardware, so hopefully there are no glaring omissions.
cpu: e5-1620 v3 4c/8t 3.50 GHz
http://ark.intel.com/products/82763/Intel-Xeon-Processor-E5-1620-v3-10M-Cache-3_50-GHz
mainboard: Supermicro X10SRA-F lga2011/c612 ATX - 10 SATA ports and 8 slots for up to 512gb RAM
http://www.supermicro.com/products/motherboard/Xeon/C600/X10SRA-F.cfm
memory: for now, just 1 stick of Samsung DDR4-2133 32GB/4Gx72 Load Reduced CL15 (supermicro recommended)
https://www.superbiiz.com/detail.php?name=D421LR32S1
discs: 3 x 4TB WS Red NAS ( I expect to config these as raidz1 for 8TB)
I have some spare SSDs I may put into this build also later on to provide low latency storage for some of the more demanding applications. Regarding the RAM, I do know that putting in an odd number of sticks does slow down memory access, but I'm hoping performance will still be plenty good enough for what I am doing initially. Later, once I get more jails running and such (and perhaps when RAM prices fall more), I expect I may add a second 32GB stick to complete the pair.
I am also still in search of a shallow depth case (15.25" or less). Affordability is important here, as it seems you can spend a ridiculous amount on good rackmount cases. I'm looking primarily for external hotswap 3.5" drive access through the front bezel (maybe 8 or 12 vertically oriented trayless slots seems ideal). It seems a 3U would be sufficient height for this, but it has been surprisingly difficult to find something like this. This item seems almost perfect, but its not short depth:
http://www.amazon.com/dp/B001OS0P8E/?tag=ozlp-20
Would appreciate your input and suggestions.
-Bill
-Bill
