get/setfacl on SCALE with NFSv4 ACLs
c77dk
Trying to test SCALE with NFSv4 ACLs, but have run into a small issue, which my search skills haven't found the solution for.
In CORE I can uset getfacl / setfacl in the cli to check/set acls if the webui cant/wont. In SCALE I see the same commands but when I run getfacl on a dataset with nfsv4 ACLs the acls isn't shown, which makes it "a little" hard to verify if the webui is telling the truth about ACLs or not.
My guess is I need some other command for the nfs permissions, but I have no luck in finding it yet. Can anyone point me in the right direction? Without ability to verify it's hard to make useful jira tickets.
anodos
Sambassador
nfs4xdr_getfacl, nfs4xdr_setfacl. If you're wanting to edit the acl you can open it in VI-like editor via `nfs4xdr_setfacl -e <path>`. That said, the correct way to interact with ACLs on SCALE is through the API. Once you have set the ACL how you want it, you can push recursively via `nfs4xdr_winacl -a clone -rv -p <path>`
anodos
Sambassador
The tools also support JSON input / output.
tn23# nfs4xdr_getfacl -j /mnt/dozer/NFS4
{"acl": [{"tag": "owner@", "id": -1, "perms": {"BASIC": "FULL_CONTROL"}, "flags": {"BASIC": "INHERIT"}, "type": "ALLOW"}, {"tag": "group@", "id": -1, "perms": {"BASIC": "MODIFY"}, "flags": {"BASIC": "INHERIT"}, "type": "ALLOW"}, {"tag": "GROUP", "who": "builtin_users", "id": 545, "perms": {"BASIC": "FULL_CONTROL"}, "flags": {"BASIC": "INHERIT"}, "type": "ALLOW"}, {"tag": "owner@", "id": -1, "perms": {"BASIC": "MODIFY"}, "flags": {"BASIC": "INHERIT"}, "type": "ALLOW"}], "nfs41_flags": {"AUTOINHERIT": false, "PROTECTED": false, "DEFAULTED": false}, "trivial": false, "uid": 1000, "gid": 1000, "path": "/mnt/dozer/NFS4"}
c77dk
thx, it works perfectly - time to have some fun testing :smile:
