Get Invalid command 'php_value' when starting apache
mysticpete
Hi
I am trying to install the package 'mythplugin-mythweb' in a jail and all goes OK until I try and fire up apache22, I get the following error
Syntax error on line 111 of /usr/local/etc/apache22/extra/mythweb.conf:
Invalid command 'php_value', perhaps misspelled or defined by a module not included in the server configuration
The package is complete as far as I can see and installs all the required supporting apps and libs, I followed the install instructions from the package but after 3 attempts I still fail to start apache.
Hunting through the forums and this issue is a bit sketchy, but appears that apache does not like the 'php_value' commands in mythweb.conf?
any assistance would be appreciated.
Is this a FreeNAS problem? Doesn't sound like it to me...
mysticpete
Agreed, not strictly speaking, the package is hosted on the FreeNas ports, just wondered that someone else may have had the same experience?
Will also post to mythtv guys.
There is no FreeNAS ports.. There's FreeBSD ports...
mysticpete
nello
I'm also trying to install mythweb.
Where do you recommend posting questions? Can you post a URL, please?
Thank you.
- nello
