Hi everyone,
Setup looks like this:
ESXi 6.5U1 fully patched
Dell R730XD
PERC H730 mini
16 x 8TB SAS drives
2 x 300GB 15K SAS drives
2 x 8c 2.4GHz CPU
128GB RAM
2 x X710 Intel 10GE NICs
1 x X540 Intyel NIC
Dell 2x10GE + 2x1GE mixed NIC
FreeNAS-9.10.2-U6 (561f0d7a1)
So, I've just had my second drive fail, and have been experimenting with simple ways to replace the drive. In short, there aren't any :-( even given the horrendous price of this server from Dell. There is no hot swap option for a passthrough SAS hard drive using the H730 mini in ESXi 6.5U1. You need to shutdown any VMs using the drive and rebuild the RDM mappings and reassign to the VM. A real PITA.
More interestingly, I am currently re-silvering my principle zpool and it's going to take about 3 hours.
Here's my question ... as I have to re-key the GELI config across the volume, can I start this prior to the re-silver completing, to avoid forgetting if I go to sleep? If not, why not?
That's it in a nutshell. BTW - Dell didn't care that I can't hot replace an H730 drive in ESXi 6.5 without shutting down the VM that consumes the drive. "I only have basic support" said the droid. I pointed out the firmware in the H730 mini and on the SAS drives was covered, and if that was breaking the AHCI behaviour it is very much Dell's problem to solve. We'll see.
Many thanks,
--RobL.
Dell R730XD
PERC H730 mini
16 x 8TB SAS drives
2 x 8c 2.4GHz CPU
128GB RAM
1 x X540 Intyel NIC
Many thanks,
--RobL.
