I'm in the process of putting together a freeNAS build to replace a windows machine primarily used as a plex media server.
Old machine has a 500gb drive for the OS, and a single 3tb drive for the media which is ~65% full.
New machine is setup with the OS on a flash drive, and a 500gb SSD for jails & network storage (not a huge need in our house for actual network storage).
What's the most logical way to get the 3TB drive into the new machine? Trying to do "Import Disk" tries to temporarily mount it and copy the data to an existing pool, problem is the existing pool isn't big enough (and I have no plans to make it so).
For right now, I have no problems having the media drive be non-redundant until a later date. So ideally if I could just mount it as a new volume without reformatting, that would great. But it seems there's no method to do this without reformatting it into ZFS?
If the only approach is to go down the "lets make it properly redundant right now" path, I'd probably go 3x3TB. Is it reasonable to make a new pool of 2x3TB, import the volume, then expand the pool to 3x3TB?
