from NAS to Azure
TSamy80
Newbie
using Synology NAS as an onsite/offsite backup . I have Server 2012 R2 Essentials with about 1TB of data. The Synology NAS claims to have built in support for backing up to Azure storage. So the NAS would backup server data locally and then to Azure. any suggestions ?
artlessknave
Senior Member
um. This is the FreeNAS forums. I see no mention of FreeNAS in your post; ask in synology, windows, or azure forums. I'm confused why you would think that asking here is going to help with unrelated systems.
artlessknave
Senior Member
that, uh, that was friendly. unless you have a question about FreeNAS (you don't seem to mention a FreeNAS version, which is one of the forum rules)...you are in the wrong place, and will most likely need to go to somewhere that answers questions about the system you mentioned, as, again, this the FreeNAS forums.
I can't think of any other way to say that than...to say it. frankly, most of the posters in the FreeNAS forum will simply ignore you cuz you have not asked a FreeNAS related question so far that I can see.
