Fresh sickrage from scratch, 11.2 Beta1
diskdiddler
2018-07-12 15:37:02 CHECKVERSION :: Unable to contact github, can't check for update: error(61, 'Connection refused')
This is from a brand new jail, created by the plugin system.
Iocage networking is fixed (tunables)
Jail can ping external IPs, I can use the fetch command even and download
https://github.com/SickRage/SickRage.git/
Someone else having this problem, here:
https://github.com/SickRage/SickRage/issues/4358
My identical, warden based sickrage is running along side, on another IP, it does not get this error.
Also
2018-07-12 15:41:51 ThreadPoolExecutor-0_1 :: Unable to contact github, can't check for update: error(61, 'Connection refused')" is now coming up in the log.
LARGE COPY AND PASTE, ifconfig (FN Host) and ifconfig (Sickrage jail)
root@freenas:~ # ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
		ether 9c:b6:54:0b:10:fe
		hwaddr 9c:b6:54:0b:10:fe
		inet 192.168.0.9 netmask 0xffffff00 broadcast 192.168.0.255
		media: Ethernet autoselect (1000baseT <full-duplex>)
		status: active
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
		groups: lo
		ether 02:f5:d5:ae:e2:00
		groups: bridge
		member: vnet0:13 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 4 priority 128 path cost 2000
		member: epair7a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 11 priority 128 path cost 2000
		member: epair6a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 10 priority 128 path cost 2000
		member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 9 priority 128 path cost 2000
		member: vnet0:4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 7 priority 128 path cost 2000
		member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 6 priority 128 path cost 2000
		member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 5 priority 128 path cost 2000
		member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: radarr
		options=8<VLAN_MTU>
		ether 02:ff:60:c1:df:ca
		hwaddr 02:ca:10:00:05:0a
		nd6 options=1<PERFORMNUD>
		status: active
		groups: epair
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: jackett
		options=8<VLAN_MTU>
		ether 02:ff:60:b1:b8:71
		hwaddr 02:ca:10:00:06:0a
		status: active
		groups: epair
vnet0:4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: qbittorrent
		options=8<VLAN_MTU>
		ether 02:ff:60:5b:ca:e5
		hwaddr 02:ca:10:00:07:0a
		status: active
		groups: epair
epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ca:10:00:09:0a
		hwaddr 02:ca:10:00:09:0a
		status: active
		groups: epair
epair6a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ca:10:00:0a:0a
		hwaddr 02:ca:10:00:0a:0a
		status: active
		groups: epair
epair7a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ca:10:00:0b:0a
		hwaddr 02:ca:10:00:0b:0a
		status: active
		groups: epair
vnet0:13: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: sickrage
		options=8<VLAN_MTU>
		ether 02:ff:60:c2:11:83
		hwaddr 02:ca:10:00:04:0a
		status: active
		groups: epair
root@freenas:~ # iocage console sickrage
Last login: Thu Jul 12 15:38:28 on pts/0
FreeBSD 11.1-STABLE (FreeNAS.amd64) #0 r325575+b31fa24ea5b(freenas/11-stable): Thu Jul  5 16:57:13 EDT 2018
Welcome to FreeBSD!
Release Notes, Errata: https://www.FreeBSD.org/releases/
Security Advisories:   https://www.FreeBSD.org/security/
FreeBSD Handbook:	  https://www.FreeBSD.org/handbook/
FreeBSD FAQ:		   https://www.FreeBSD.org/faq/
Questions List: https://lists.FreeBSD.org/mailman/listinfo/freebsd-questions/
FreeBSD Forums:		https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with:  pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed:  freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages:  man man
FreeBSD directory layout:	  man hier
Edit /etc/motd to change this login announcement.
root@sickrage:~ # ifconfig
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
		groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ff:60:c2:11:84
		hwaddr 02:ca:10:00:08:0b
		inet 192.168.0.127 netmask 0xffffff00 broadcast 192.168.0.255
		status: active
		groups: epair
root@sickrage:~ #
Anyone else? Any thoughts?
NOTE: I've changed DHCP to manual for this jail too, no dice.
KrisBee
Can't install any plugins in the new BETA as I just get DNS errors. But you can install it by creating a jail first and then simply follow the plugin json at https://github.com/freenas/iocage-ix-plugins/blob/master/sickrage.json
That means first installing three packages( & their dependencies) in your jail:
lang/python27
security/ca_root_nss
databases/py-sqlite3
and then follow steps in https://github.com/freenas/iocage-plugin-sickrage.git
#!/bin/sh
# Create user and set up the directorys
pw useradd -n sickrage -c "Sickrage" -s /sbin/nologin -w no
fetch https://github.com/SickRage/SickRage/archive/master.tar.gz
tar xfz master.tar.gz -C /usr/local/
mv /usr/local/SickRage-master /usr/local/sickrage
chown -R sickrage:sickrage /usr/local/sickrage
mkdir /usr/local/etc/rc.d
# Enable
sysrc -f /etc/rc.conf sickrage_enable="YES"
# Copy the init script where it's useful
cp /usr/local/sickrage/runscripts/init.freebsd /usr/local/etc/rc.d/sickrage
chmod +x /usr/local/etc/rc.d/sickrage
# Start the service
service sickrage start
diskdiddler
The DNS issues? I had those, did you do the tunables fix?
SHOrage
#Created it like this but no webgui
# Install PKG and Update and Upgrade
pkg update
pkg upgrade
# Install Packages
pkg install lang/python27
pkg install security/ca_root_nss
pkg install databases/py-sqlite3
#!/bin/sh
mv /usr/local/SiCKRAGE-master /usr/local/sickrage # <----case correction
# Enable
# Start the service
Snow
Has this change at all now that 11.2-U4.1 or I am doing it wrong? I fell like I am missing a step .
This has always work for me in the past.
