FreeNAS Users can read each each others home directories via SMB
ovizii
I've created 2 users and 2 shares via the wizard. I then set these 2 directories as their home directories and now they can simply mount each others directories and read them.
I went to edit my users and have edited the users, down in the home directory mode, I have unticked all 3 boxes for "other" but every time I open the user properties again, those boxes are back.
=> http://screencast.com/t/NwcBtdouxDq
I manually checked one such home directory and it looks like this:
freenas# ls -al Ovi
total 236
drwxrwxr-x+  4 ovi   ovi       10 May 19 19:04 .
drwxr-xr-x  10 root  wheel     10 May 19 18:24 ..
-rwxrwxr-x+  1 ovi   ovi    14340 May 19 19:04 .DS_Store
-rwxrwxr-x+  1 ovi   ovi     4096 May 17 23:46 ._.DS_Store
-rwxrwxr-x+  1 ovi   ovi       80 May 19 18:18 .histfile
-rwxrwxr-x+  1 ovi   ovi        0 May 17 22:44 .windows
-rwxrwxr-x+  1 ovi   ovi    36559 May 17 23:50 .zcompdump
-rwxrwxr-x+  1 ovi   ovi      381 May 17 23:50 .zshrc
drwxrwxr-x+  3 ovi   ovi        5 May 19 19:04 Documents
drwxrwxr-x+  6 ovi   ovi       10 May 18 11:05 _temp storage
How do I correct this via the GUI or alternatively via the command line?
###edit###
NOT blaming freeNAS, I'm sure I made a booboo, actually I can remember at least one:
While fiddling with this one share I checked the box "Use as home share:" and only later did I realize that this would be a general share holding ALL home folders so I unticked the box. I guess this could be one of the reasons why this is messed up?
ovizii
Solved it myself but I'm unsure if this is the best solution:
getfacl Alex
# file: Alex
# owner: alex
# group: alex
            owner@:rwxpDdaARWcCos:fd----:allow
            group@:rwxpDdaARWcCos:fd----:allow
         everyone@:r-x---a-R-c---:fd----:allow
freenas# setfacl -x everyone@:r-x---a-R-c---:fd----:allow  Alex
freenas# getfacl Alex
# file: Alex
# owner: alex
# group: alex
SweetAndLow
Sweet'NASty
You are using ACL's so you need to modify the permissions of each share using the windows gui or by using the cli like you did.
ovizii
Thanks for confirming. I don't have Windows handy (please don't ask why I am using smb then) but as long as what I did wasn't detrimental its all good.
