Installed freenas in bhyve vm with 8g ram, upgraded to latest version yesterday then upgraded to TrueNAS.
Noticed on console running the system:
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.916727-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.916851-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.916883-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to reconnect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.916937-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933089-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933501-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933552-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933594-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933635-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933675-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933719-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933759-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933798-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933842-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933885-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933938-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.933982-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.934022-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
2020-09-28T20:04:24.934061-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.969450-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.976594-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.976771-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.982611-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.982754-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.983649-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.984805-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.986492-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997351-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997372-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997393-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997409-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997452-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997492-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997532-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997571-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997615-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997655-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997693-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997732-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:24 freenas 1 2020-09-28T20:04:24.997773-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
2020-09-28T20:04:24.997812-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.050099-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.055922-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.055949-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.057446-07:00 freenas.local collectd 6745 - - rrdcached plugin: Failed to connect to RRDCacheD at unix:/var/run/rrdcached.sock: Unable to connect to rrdcached: No such file or directory (status=2)
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.098174-07:00 freenas.local /middlewared 133 - - [EtcService:335] Failed to render mako:local/collectd.conf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/etc.py", line 324, in generate
    rendered = await renderer.render(path)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/etc.py", line 46, in render
    return await self.service.middleware.run_in_thread(do)
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/etc.py", line 38, in do
    return tmpl.render(
  File "/usr/local/lib/python3.8/site-packages/mako/template.p
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.108280-07:00 freenas.local /middlewared 133 - - y", line 475, in render
    return runtime._render(self, self.callable_, args, data)
  File "/usr/local/lib/python3.8/site-packages/mako/runtime.py", line 877, in _render
    _render_context(
  File "/usr/local/lib/python3.8/site-packages/mako/runtime.py", line 919, in _render_context
    _exec_template(inherit, lclcontext, args=args, kwargs=kwargs)
  File "/usr/local/lib/python3.8/site-packages/mako/runtime.py", line 946, in _exec_template
    callable_(context, *args, **kwargs)
  File "/tmp/mako/usr/local/lib/python3.8/site-packages/middlewared/etc_files/local/collectd.conf.py", line 25, in render_body
    if not middleware.call_sync('reporting.setup'):
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1260, in call_sync
    return methodobj(*prepared_call.args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/reporting/configure.py", line 93, in setup
    os.symlink(os.path.join(pwd, 'localho
Sep 28 20:04:25 freenas 1 2020-09-28T20:04:25.118384-07:00 freenas.local /middlewared 133 - - st'), os.path.join(pwd, hostname))
FileExistsError: [Errno 17] File exists: '/var/db/collectd/rrd/localhost' -> '/var/db/collectd/rrd/freenas.local'
