just for reference:
MoBo: ASUS N4L-VM-DH Sockel 479
CPU: Intel T7200 Core 2 Duo 2GHz
RAM: 2 x 1 GB DDR2
PSU: beQuiet 300W
HD: 2 x WD3200BEKT scorpio black 2.5" SATA2 (7200rpm)
freeNAS-x64
IDLE: 30.5W
BUSY: 39W
issues:
it is an old board, it has
2 SATA1 + PATA (Intel ® ICH7-M DH Southbridge:- 1 x UltraDMA 100/66/33 - 2 x Serial ATA supports RAID 0, 1 and Intel ® Matrix Storage Technology)
2 SATA2 (JMicron SATA Controller: 1 x Internal Serial ATA 3,0 Gb / s + 1 x External Serial ATA 3,0 Gb / s (SATA On-the-Go), RAID 0, 1 support)
GBit LAN (Intel 82573L Gb Ethernet (Vidalia))
1 x PCI-E x 16
1 x PCI-E x 1
2 x PCI
The mobo has 2 SATAII Ports (1 internal, 1 eSATA at the JMicron), but only one is recognized by freeBSD at full SATA2 speed, the other stays at SATA1.
However, configured at RAID1 zfs, 500Mbps Transferrate is O.K. and it is low-power.
By the way, is there a way to put the CPU / Graphics to sleep - e.g. turn off the monitor instead of a screen saver?
I plan a new setup with a more recent bord:
ZOTAC M880G-ITX
AMD Turion II Neo Dual-Core K625 1,5GHz
6 SATAIII (6Gbps), 2 USB 3.0 + 6 USB 2.0
1Gbit LAN + WiFi 802.11n
Mini-ITX
8GB DDR3 RAM
same drives, psu as above
I want to test the performance difference / power consumption and will post the results later here.
(more ram, faster sata lanes, will also remove the wifi later to see if this saves some more watts)
just for reference:
RAM: 2 x 1 GB DDR2
PSU: beQuiet 300W
freeNAS-x64
IDLE: 30.5W
BUSY: 39W
issues:
1 x PCI-E x 16
1 x PCI-E x 1
2 x PCI
ZOTAC M880G-ITX
Mini-ITX
8GB DDR3 RAM
