FreeNas System Alert
RemyZ
The capacity for the volume 'freenas-boot' is currently at 80%, while the recommended value is below 80%
I am getting this system alert message when my Satadomm is 64gib in size.
Scrub BootStatus
Boot Volume Condition: HEALTHY
Size:
59.5 GiB
Used: 48.1 GiB (80%) <---Help me understand how is this possible
I have recently updated the boot drive but this message come up beforehand. I have also factory reset twice
Jailer
Not strong, but bad
Delete some of your old unused boot environments.
BigDave
FreeNAS Enthusiast
Please post a screenie of your System > Boot tab window.
I'm with Mirfster, I gotta see 48Gbits of updates on a X11 board :eek: :eek: :eek:
RemyZ
Attached
Mirfster
BigDave
FreeNAS Enthusiast
Come on man, you doctored that picture or somethin' right?
On a more serious note, you have something goin' on with that DOM sir,
that is just strange.
You're pullin' our forum leg, aren't ya?
BigDave
FreeNAS Enthusiast
Hey, I think I know what this is. The flash chip is near it's block erase limit,
so FreeNAS is reading what it needs to run FreeNAS and it's filling up now.
Was this DOM purchased new OR used?
RemyZ
The dom was purchased new. I deleted the default and initial install in a panic rush and willing to start over since I dont have anything substantial on it at the moment.
BigDave
FreeNAS Enthusiast
I'd fire up ssh and see what SMART lists as size/capacity for the DOM.
You won't be able to test it, but it should give basic info...
RemyZ
at this point what is the best way to start over from scractch as in
Reformat the Satadomm
Reinstall Freenas ?
RemyZ
what is the best way to format the satadomm ???
RemyZ
No, I dont believe so.
RemyZ
Should I just delete Datasets then reformat the Satadomm and reinstall OS ?
BigDave
FreeNAS Enthusiast
RemyZ
What commands should I run once ssh'ed in ?
BigDave
FreeNAS Enthusiast
[root@freenas] ~# smartctl -a /dev/ada0
copy and paste results here using [ code ] tags
RemyZ
Device Model:     SATA SSD
Serial Number:    B45007570B2400105533
Firmware Version: S9FM02.1
User Capacity:    64,023,257,088 bytes [64.0 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      Unknown (0x0008)
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 (minor revision not indicated)
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Mar  6 08:46:41 2016 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (   30) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
Conveyance self-test routine
  1 Raw_Read_Error_Rate     0x000a   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       797
12 Power_Cycle_Count       0x0012   100   100   000    Old_age   Always       -       74
168 Unknown_Attribute       0x0012   100   100   000    Old_age   Always       -       0
169 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       40
170 Unknown_Attribute       0x0013   100   100   010    Pre-fail  Always       -       25
173 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       458753
192 Power-Off_Retract_Count 0x0012   100   100   000    Old_age   Always       -       1
194 Temperature_Celsius     0x0023   070   070   000    Pre-fail  Always       -       30
196 Reallocated_Event_Count 0x0000   100   100   000    Old_age   Offline      -       0
218 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       0
231 Temperature_Celsius     0x0013   100   100   000    Pre-fail  Always       -       99
233 Media_Wearout_Indicator 0x0013   100   100   000    Pre-fail  Always       -       68900
241 Total_LBAs_Written      0x0012   100   100   000    Old_age   Always       -       59096
242 Total_LBAs_Read         0x0012   100   100   000    Old_age   Always       -       4421
246 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       12380
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
