FreeNAS Security output, long.
avalon60
This morning I received a right long security output from my FreeNAS box.
The usual reports I get are around half a dozen lines or less, but this one has about 200 lines at a guess. This one is mostly to do with the hardware: USB drives, CPU, AHCI, PCI Slots, VGA , Coretemp and all the hard rives installed.
I wonder if it is to do with the new Xeon cpu I installed yesterday.
Bidule0hm
Server Electronics Sorcerer
It would be useful to attach the output to your post... :)
Note that you shouldn't get any report at all, if you get one then something is wrong (or you rebooted the server in the last 24h).
avalon60
I did reboot the server yesterday after installing the Xeon cpu, and that is why I said that in my first post.
Ok, here it is:
I have had to do it in 5 parts because there were more than 3000 characters.
freenas.local kernel log messages:
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p12 #2 r275790+e006356: Thu Mar 26 17:28:49 PDT 2015
root@build3.ixsystems.com:/tank/home/jkh/build/FN/objs/os-base/amd64/tank/home/jkh/build/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU E3-1240 V2 @ 3.40GHz (3400.09-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306a9 Family = 0x6 Model = 0x3a Stepping = 9
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x7fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
Standard Extended Features=0x281<GSFSBASE,SMEP,ENHMOVSB>
TSC: P-state invariant, performance statistics
real memory = 17985175552 (17152 MB)
avail memory = 16489066496 (15725 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
avalon60
2nd part
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <PCI-PCI bridge> mem 0xdfb00000-0xdfb1ffff irq 16 at device 0.0 on pci1
pci2: <PCI bus> on pcib2
pcib3: <PCI-PCI bridge> irq 17 at device 1.0 on pci2
pci3: <PCI bus> on pcib3
pci3: <serial bus, USB> at device 0.0 (no driver attached)
pcib4: <PCI-PCI bridge> irq 17 at device 5.0 on pci2
pci4: <PCI bus> on pcib4
ahci0: <Marvell 88SE912x AHCI SATA controller> port 0xe040-0xe047,0xe030-0xe033,0xe020-0xe027,0xe010-0xe013,0xe000-0xe00f mem 0xdf910000-0xdf9107ff irq 17 at device 0.0 on pci4
ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
ahci0: quirks=0x40<EDGEIS>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib5: <PCI-PCI bridge> irq 19 at device 7.0 on pci2
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> irq 17 at device 9.0 on pci2
pci6: <PCI bus> on pcib6
em0: <Intel(R) PRO/1000 Network Connection 7.4.2> port 0xf020-0xf03f mem 0xdfd00000-0xdfd1ffff,0xdfd25000-0xdfd25fff irq 20 at device 25.0 on pci0
em0: Using an MSI interrupt
em0: Ethernet address: 0c:c4:7a:0c:1e:ef
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xdfd24000-0xdfd243ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci7: <ACPI PCI bus> on pcib7
pcib8: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci8: <ACPI PCI bus> on pcib8
em1: <Intel(R) PRO/1000 Network Connection 7.4.2> port 0xd000-0xd01f mem 0xdfc00000-0xdfc1ffff,0xdfc20000-0xdfc23fff irq 16 at device 0.0 on pci8
em1: Using MSIX interrupts with 3 vectors
em1: Ethernet address: 0c:c4:7a:0c:1e:ee
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xdfd23000-0xdfd233ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
pcib9: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci9: <ACPI PCI bus> on pcib9
vgapci0: <VGA-compatible display> mem 0xde000000-0xdeffffff,0xdf800000-0xdf803fff,0xdf000000-0xdf7fffff irq 23 at device 3.0 on pci9
vgapci0: Boot video device
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
avalon60
3rd part:
ahci1: <Intel Cougar Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf000-0xf01f mem 0xdfd22000-0xdfd227ff irq 19 at device 31.2 on pci0
ahci1: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 10 on acpi0
ichwd0 on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xcb800-0xcc7ff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub2: 6 ports with 6 removable, self powered
uhub3: 6 ports with 6 removable, self powered
avalon60
4th part:
ugen1.3: <SanDisk> at usbus1
umass0: <SanDisk Cruzer Blade, class 0/0, rev 2.00/1.27, addr 3> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0x0100
umass0:9:0:-1: Attached to scbus9
ugen0.4: <Kingston> at usbus0
umass1: <Kingston DataTraveler 2.0, class 0/0, rev 2.00/1.00, addr 4> on usbus0
umass1: SCSI over Bulk-Only; quirks = 0xc100
umass1:10:1:-1: Attached to scbus10
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD10PURX-64D85Y0 01.01A01> ATA-9 SATA 3.x device
da0 at umass-sim0 bus 0 scbus9 target 0 lun 0
da0: <SanDisk Cruzer Blade 1.27> Removable Direct Access SCSI-6 device
da0: Serial Number 4C530799910624101524
da0: 40.000MB/s transfers
da0: 15267MB (31266816 512 byte sectors: 255H 63S/T 1946C)
da0: quirks=0x2<NO_6_BYTE>
da1 at umass-sim1 bus 1 scbus10 target 0 lun 0
da1: <Kingston DataTraveler 2.0 1.00> Removable Direct Access SCSI-4 device
da1: Serial Number C860008863CFCE819A1680D6
da1: 40.000MB/s transfers
da1: 7396MB (15148608 512 byte sectors: 255H 63S/T 942C)
da1: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
ada0: Serial Number WD-WCC4J5XC8EYT
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich2 bus 0 scbus2 target 0 lun 0
ada1: <WDC WD20EFRX-68EUZN0 82.00A82> ATA-9 SATA 3.x device
ada1: Serial Number WD-WCC4MP4L4UH9
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad8
ada2 at ahcich3 bus 0 scbus3 target 0 lun 0
ada2: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada2: Serial Number WD-WMC300412931
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad10
ada3 at ahcich4 bus 0 scbus4 target 0 lun 0
ada3: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada3: Serial Number WD-WMC300187339
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad12
ada4 at ahcich5 bus 0 scbus5 target 0 lun 0
ada4: <WDC WD20EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada4: Serial Number WD-WMC300412900
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad14
ada5 at ahcich6 bus 0 scbus6 target 0 lun 0
ada5: <WDC WD10EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device
ada5: Serial Number WD-WCAZAA568514
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada5: quirks=0x1<4K>
ada5: Previously was known as ad16
ada6 at ahcich7 bus 0 scbus7 target 0 lun 0
ada6: <WDC WD10EARS-003BB1 80.00A80> ATA-8 SATA 2.x device
ada6: Serial Number WD-WCAV5J838621
ada6: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada6: quirks=0x1<4K>
ada6: Previously was known as ad18
avalon60
5th part:
SMP: AP CPU #1 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #3 Launched!
Timecounter "TSC-low" frequency 1700047416 Hz quality 1000
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201503270027 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
MCA: Bank 0, Status 0x9400004000040150
MCA: Global Cap 0x0000000000000c09, Status 0x0000000000000000
MCA: Vendor "GenuineIntel", ID 0x306a9, APIC ID 4
MCA: CPU 4 COR (1) ICACHE L0 IRD error
MCA: Address 0x80088b530
MCA: Vendor "GenuineIntel", ID 0x306a9, APIC ID 5
MCA: CPU 5 COR (1) ICACHE L0 IRD error
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 3.19, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
ipmi1: <IPMI System Interface> on isa0
device_attach: ipmi1 attach returned 16
MCA: Address 0x80088e530
MCA: Bank 0, Status 0xd40000c000040150
MCA: CPU 4 COR (3) OVER ICACHE L0 IRD error
MCA: Address 0x1ffff80db8534
MCA: Address 0x1ffff803e6530
MCA: Address 0x1ffff80972530
MCA: Bank 0, Status 0xd400008000040150
MCA: CPU 5 COR (2) OVER ICACHE L0 IRD error
MCA: Address 0x1ffff808ef530
MCA: CPU 5 COR (3) OVER ICACHE L0 IRD error
MCA: Address 0x800837530
MCA: Address 0x1ffff803d8530
MCA: Address 0x1ffff803aa530
MCA: CPU 4 COR (2) OVER ICACHE L0 IRD error
MCA: Address 0x1ffff803d8533
MCA: Address 0x1ffff8092e530
MCA: Address 0x1ffff8093e530
MCA: Address 0x1ffff80db7530
MCA: Address 0x1ffff80960530
MCA: Address 0x1ffff8093f530
MCA: Address 0x1ffff8093f537
MCA: Address 0x800899530
MCA: Address 0x1ffff807bb530
MCA: Address 0x1ffff807b9530
MCA: Address 0x1ffff809e9530
GEOM_ELI: Device ada5p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device ada6p1.eli created.
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada0p1.eli created.
vboxdrv: fAsync=0 offMin=0x2d3 offMax=0xf08
pid 1889 (syslog-ng), uid 0: exited on signal 6 (core dumped)
CPU: Intel(R) Xeon(R) CPU E3-1240 V2 @ 3.40GHz (3400.10-MHz K8-class CPU)
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
ichwd0 on isa0
kbd0 at atkbd0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen0.3: <Winbond Electronics Corp> at usbus0
ums0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ukbd0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
kbd2 at ukbd0
Timecounter "TSC-low" frequency 1700051662 Hz quality 1000
vboxdrv: fAsync=0 offMin=0x2dd offMax=0xef5
-- End of security output --
D
dlavigne
Guest
That's to be expected when the system reboots (those are system startup messages).
avalon60
As I said in my first post that I thought it may have been because I installed a new Xeon cpu yesterday.
Thanks
Bidule0hm
Well, this look bad. AFAIK it's the cache of the CPU who doesn't do well...
So, you need to check the following:
  • that you're 100% sure the CPU is correctly seated in his socket? (the socket and CPU pins/pads were clean?)
  • that the CPU cooler is correctly installed (with thermal paste, makes good and flat contact with the CPU, fan running ok, ...)
  • the PSU
What is your hardware? it's new?
