John Richardson
- May 17, 2014
Hi all,
Sorry, I'm admittedly a newb, but I'm working on learning more! I recently had a drive report smart errors, but it was a WD black that wasn't designed for NAS work and I didn't know about a change that I needed to make to the drive (I'm forgetting what it was now) until it was too late(ish) and the drive was already on it's way out. The other three drives are WD Reds, and the fourth replacement drive is a HGST.
Anyhow, I replaced the black with the HGST and resilvered. All went swimmingly. Now, a couple of weeks later I have a couple of drives reporting smart errors from the dashboard:
So I jumped into the shell and ran "smartctl -a /dev/ada_" for all four drives. Below is a copy of that information. If anyone sees something I don't, or has any ideas on how to fix this that would be GREAT! :)
I hope my disks are still ok, though I think the reds are all still under warranty with WD so I can easily RMA them if need be.
Thanks in advance!
John
Drive 0:
Drive 1:
Drive 2 (this is the HGST, the one that was just replaced):
Drive 3:
- CRITICAL: Device: /dev/ada3, failed to read SMART Attribute Data
- CRITICAL: Device: /dev/ada1, failed to read SMART Attribute Data
- OK: There is a new update available! Apply it in System -> Update tab.
Thanks in advance!
John
Drive 0:
[root@freenas] ~# smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N0847776
LU WWN Device Id: 5 0014ee 25f466952
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Nov 15 22:57:26 2015 EST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (38160) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 383) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 195 176 021 Pre-fail Always - 5216
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 138
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 12001
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 118
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 64
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 163
194 Temperature_Celsius 0x0022 117 104 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 10838 -
# 2 Short offline Completed without error 00% 10670 -
# 3 Extended offline Completed without error 00% 10582 -
# 4 Short offline Completed without error 00% 10502 -
# 5 Short offline Completed without error 00% 10286 -
# 6 Extended offline Completed without error 00% 10222 -
# 7 Short offline Completed without error 00% 10094 -
# 8 Short offline Completed without error 00% 9926 -
# 9 Extended offline Completed without error 00% 9839 -
#10 Short offline Completed without error 00% 9759 -
#11 Short offline Completed without error 00% 9543 -
#12 Extended offline Completed without error 00% 9484 -
#13 Short offline Completed without error 00% 9351 -
#14 Short offline Completed without error 00% 9183 -
#15 Extended offline Completed without error 00% 9098 -
#16 Short offline Completed without error 00% 9015 -
#17 Short offline Completed without error 00% 8824 -
#18 Extended offline Completed without error 00% 8761 -
#19 Short offline Completed without error 00% 8632 -
#20 Short offline Completed without error 00% 8464 -
#21 Extended offline Completed without error 00% 8376 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Drive 1:
[root@freenas] ~# smartctl -a /dev/ada1
Serial Number: WD-WCC4N0901970
LU WWN Device Id: 5 0014ee 25f5ce875
Local Time is: Sun Nov 15 22:55:43 2015 EST
was never started.
been run.
data collection: (38940) seconds.
command.
power-saving mode.
recommended polling time: ( 391) minutes.
3 Spin_Up_Time 0x0027 194 176 021 Pre-fail Always - 5266
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 137
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 12000
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 117
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 160
194 Temperature_Celsius 0x0022 117 106 000 Old_age Always - 33
No Errors Logged
# 1 Short offline Completed without error 00% 10837 -
# 2 Short offline Completed without error 00% 10669 -
#10 Short offline Completed without error 00% 9758 -
#11 Short offline Completed without error 00% 9542 -
#17 Short offline Completed without error 00% 8823 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~#Drive 2 (this is the HGST, the one that was just replaced):
[root@freenas] ~# smartctl -a /dev/ada2
Model Family: HGST Deskstar NAS
Device Model: HGST HDN724030ALE640
Serial Number: PK2234P9HXR8WY
LU WWN Device Id: 5 000cca 248db258e
Firmware Version: MJ8OA5E0
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
Local Time is: Sun Nov 15 22:57:32 2015 EST
^[[ASMART overall-health self-assessment test result: PASSED
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time: ( 443) minutes.
SCT capabilities: (0x003d) SCT Status supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 85
3 Spin_Up_Time 0x0007 100 100 024 Pre-fail Always - 0
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 1
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 441
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 7
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 7
194 Temperature_Celsius 0x0002 176 176 000 Old_age Always - 34 (Min/Max 21/36)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Drive 3:
[root@freenas] ~# smartctl -a /dev/ada3
Serial Number: WD-WCC4N0889597
LU WWN Device Id: 5 0014ee 20a072f8d
Local Time is: Sun Nov 15 22:57:38 2015 EST
was never started.
been run.
data collection: (39060) seconds.
command.
power-saving mode.
recommended polling time: ( 392) minutes.
3 Spin_Up_Time 0x0027 181 175 021 Pre-fail Always - 5933
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 162
194 Temperature_Celsius 0x0022 118 108 000 Old_age Always - 32
No Errors Logged
#11 Short offline Interrupted (host reset) 90% 9543 -
#15 Extended offline Completed without error 00% 9099 -
#21 Extended offline Completed without error 00% 8377 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~#
