Matej Jurkic
- Jun 25, 2013
Hi all,
I'd need some (a lot) help, regarding setting PPTP connection on my FreeNAS computer.
System info is as follows:
System Information
Hostname freenas.local
Build FreeNAS-8.3.1-RELEASE-p2-x86 (r12686+b770da6)
Platform Intel(R) Celeron(R) CPU 2.66GHz
Memory 495MB
System Time Tue Jun 25 12:16:49 PDT 2013
Uptime 12:16PM up 5:11, 1 user
Load Average 0.29, 0.27, 0.16
Connected through 192.168.0.104
I need PPTP connection to connect to my ISP.
I've read here that mpd5 should be installed, but I can not make it happen.
I've downloaded last mpd5 version from here, copied it with WinSCP (using ssh, connecting as root) in "/tmp/pppt/ " folder, extracted the tarball and ran "make install all".
Which gives me this:
===> src (install)
install -s -o root -g wheel -m 555 mpd5 /usr/local/sbin
install: mpd5: No such file or directory
*** Error code 71
Stop in /var/tmp/pptptemp/mpd-5.7/src.
*** Error code 1
Stop in /var/tmp/pptptemp/mpd-5.7.
On the other hand "make all install" gives me this:
===> src (all)
Warning: Object directory not changed from original /var/tmp/pptptemp/mpd-5.7/src
cc -O2 -pipe -DPROTO_NAME_LIST -DUSE_WRAP -DUSE_PAM -DUSE_SYSTEM -DPATH_CONF_DIR=\"/usr/local/etc/mpd5\" -DSYSLOG_FACILITY=LOG_DAEMON -DMPD_VERSION='"5.7 (root@freenas.local 12:28 25-Jun-2013)"' -g -Wall -Wcast-align -Wchar-subscripts -Wformat -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wwrite-strings -pthread -I/usr/local/include -DNOLIBPDEL -I./contrib/libpdel -DPHYSTYPE_MODEM -DPHYSTYPE_UDP -DPHYSTYPE_TCP -DPHYSTYPE_NG_SOCKET -DPHYSTYPE_PPTP -DRANDOMIZE_CID -DPHYSTYPE_PPPOE -DPHYSTYPE_L2TP -DCCP_DEFLATE -DUSE_NG_DEFLATE -DCCP_MPPC -DUSE_NG_MPPC -DCCP_PRED1 -DUSE_NG_PRED1 -DECP_DES -DUSE_NG_BPF -DUSE_NG_CAR -DUSE_NG_IPACCT -DUSE_NG_NAT -DUSE_NG_NETFLOW -DUSE_NG_TCPMSS -DUSE_NG_VJC -DUSE_IPFW -DUSE_FETCH -std=gnu99 -fstack-protector -c modem.c
cc: not found
*** Error code 127
*** Error code 1
Please, point me in right direction.
Many thanks,
Matthew the noob
System Information
Memory 495MB
===> src (install)
*** Error code 71
*** Error code 1
===> src (all)
cc: not found
*** Error code 127
*** Error code 1
Many thanks,
Matthew the noob
