freenas kernel: 5 done
gearhead
I am getting the subject message. What does it mean? Using FreeNAS-9.1.1-RELEASE-x64 (a752d35)
D
dlavigne
Guest
I'm assuming this is in /var/log/messages? If so, please post the output of that file so we can get some context for the message.
gearhead
Below is a portion of messages:
Sep 5 08:23:18 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
Sep 5 08:23:18 freenas kernel: mountroot: waiting for device /dev/ufs/FreeNASs1a ...
Sep 5 08:23:18 freenas kernel: da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
Sep 5 08:23:18 freenas kernel: da0: < Patriot Memory PMAP> Removable Direct Access SCSI-4 device
Sep 5 08:23:18 freenas kernel: da0: 40.000MB/s transfers
Sep 5 08:23:18 freenas kernel: da0: 7385MB (15124992 512 byte sectors: 255H 63S/T 941C)
Sep 5 08:23:18 freenas kernel: da0: quirks=0x2<NO_6_BYTE>
Sep 5 08:23:18 freenas kernel: ZFS filesystem version: 5
Sep 5 08:23:18 freenas kernel: ZFS storage pool version: features support (5000)
Sep 5 08:23:18 freenas kernel: GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
Sep 5 08:23:18 freenas kernel: GEOM_ELI: Device ada0p1.eli created.
Sep 5 08:23:18 freenas kernel: GEOM_ELI: Encryption: AES-XTS 256
Sep 5 08:23:18 freenas kernel: GEOM_ELI: Crypto: software
Sep 5 08:23:18 freenas kernel: GEOM_ELI: Device ada1p1.eli created.
Sep 5 08:23:18 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Sep 5 08:23:19 freenas ntpd[1611]: ntpd 4.2.4p5-a (1)
Sep 5 08:23:19 freenas kernel: .
Sep 5 08:23:19 freenas kernel: .......+++
Sep 5 08:23:20 freenas smartd[1878]: Device: /dev/ada0, WARNING: A firmware update for this drive may be available,
Sep 5 08:23:20 freenas smartd[1878]: see the following Seagate web pages:
Sep 5 08:23:20 freenas smartd[1878]: http://knowledge.seagate.com/articles/en_US/FAQ/207931en
Sep 5 08:23:20 freenas smartd[1878]: http://knowledge.seagate.com/articles/en_US/FAQ/213891en
Sep 5 08:23:27 freenas avahi-daemon[2031]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep 5 08:23:27 freenas avahi-daemon[2031]: Failed to open /etc/resolv.conf: No such file or directory
Sep 5 08:23:28 freenas last message repeated 2 times
Sep 5 08:23:28 freenas kernel: 5
Sep 5 08:23:29 freenas kernel: done.
Sep 5 08:37:15 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Yatti420
A side note looks like you have a seagate drive in need of a firmware update see here.. Are you sure the install is clean? Checked checksum after download?
gearhead
yes. I'll re-download FreeNAS and install again over the weekend.
gearhead
Just to clarify. It was a clean install, however profile was read in from 8.3.1
Z300M
I get that message for several of my Seagate drives, but when I check on the Seagate Web site, they are all up to date -- four same-model drives with three different fw revisions between them.
