FreeNAS iSCSI MPIO RR limited to 1Gb/sec
zeroluck
I have set up about 5 different FreeNAS boxes connected to ESXi by now and have followed the same procedure to set them up with MPIO, but no matter what I do I can only get the throughput of 1Gb/s to any of the boxes.
Here's what I've done:
  • Set up two NIC on FreeNAS on different subnets with MTU 9000
  • Set up two NIC on ESXi on different subnets with MTU 9000 with iscsi port binding
  • Enable Round Robin (Active I/O on both Nics)
  • Verify connectivity to both NIC
  • Verify both paths are active and working
  • Set RR IOPS to 1
Still I see only 1Gb/s or less on both nics at any given moment. If I disable RR and use vmware last used path or fixed, I see it max out the single connection. I see that this problem is common on the forums but I don't see a straightforward answer to it. My config:
ESXi:
iSCSI C: 10.0.3.41
iSCSI D: 10.0.4.41
FreeNAS:
iSCSI 1 igb0: 10.0.3.27
iSCSI 2 igb1: 10.0.4.27
connections on esxi:
[root@esxi-02:~] esxcli network ip connection list | grep 10.0.3
tcp         0       0  10.0.3.41:27551     10.0.3.27:3260       ESTABLISHED   3615380  newreno  vmm0:Zimbra_Archive
tcp         0       0  10.0.3.41:43698     10.0.3.25:3260       ESTABLISHED         0  newreno
tcp         0       0  10.0.3.41:427       0.0.0.0:0            LISTEN          34525  newreno
udp         0       0  10.0.3.41:123       0.0.0.0:0                            33892           ntpd
[root@esxi-02:~] esxcli network ip connection list | grep 10.0.4
tcp         0       0  10.0.4.41:10656     10.0.4.27:3260       ESTABLISHED         0  newreno
tcp         0       0  10.0.4.41:23905     10.0.4.25:3260       ESTABLISHED     32806  newreno  idle0
tcp         0       0  10.0.4.41:427       0.0.0.0:0            LISTEN          34525  newreno
udp         0       0  10.0.4.41:123       0.0.0.0:0                            33892           ntpd
Network speed:
(at 12:35 I switched it from last used path to round robin)
Are there settings that I should be tweaking to make this go faster? Right now I'm just using vMotion to test the speed. I realize in this example it wasn't maxing out the single connection before switching, so maybe this vMotion is just a bad example, but this is a pattern so far. I will work on a better benchmark to show the difference here, but I am still open to suggestions.
zambanini
on the vsphere cli you need to set io switching to 1, there are a couple of forum posts regarding that topic.
post the cli output for the io switching part and how you tested your setup
zeroluck
I already did that:
naa.6589cfc000000c3c181a4d82fe5a96b7
   Device Display Name: Storage1-A
   Storage Array Type: VMW_SATP_ALUA
   Storage Array Type Device Config: {implicit_support=on;explicit_support=off; explicit_allow=on;alua_followover=on; action_OnRetryErrors=off; {TPG_id=1,TPG_state=AO}}
   Path Selection Policy: VMW_PSP_RR
   Path Selection Policy Device Config: {policy=iops,iops=1,bytes=10485760,useANO=0; lastPathIndex=0: NumIOsPending=0,numBytesPending=0}
   Path Selection Policy Device Custom Config:
   Working Paths: vmhba38:C7:T12:L0, vmhba38:C2:T12:L0
   Is USB: false
toadman
I have had the same issue for a couple years. Finally virtualized FreeNAS and switched to NFS and 10G vnics on the same server. It's faster.
