FreeNAS extremely slow after mount -uw /?
codenamezero
Anyone experience this issue? whenever i mount -uw, everything become super slow, takes several seconds before I get a response on the webui or in the ssh session... any idea?
califrag
yep i've experienced this as well. not sure what happens but goes away as soon as mount -ur / is executed..
jgreco
Resident Grinch
Haven't seen that, but look for exploding I/O rates ("iostat 1") to the flash device as a likely cause. My guess would be something trying to write to the flash. If you do see higher I/O rates to the flash, it'd be interesting to see if we can figure out what is causing it, because "That's Bad[tm]".
codenamezero
Hum... that's weird though, i mean the NAS function perfectly fine with write being off, why would all of the sudden it starts writing all sort of things to the disk just because write is enabled?
I mean when i talk about lag, is not when i do a pkg_add and it start writing stuff, i'm only talking about doing simple task like ls or pwd, it would still lag like crazy from (1 to 10 seconds).
califrag
Yep this is the exact same behavior that I was experiencing. I would type a simple command like ls -l and hit enter, terminal would hang for 5-10 seconds then the command goes through. Same with some simple stuff like mv and cp and even just cd .. would take several seconds to execute.
jgreco
Resident Grinch
The marvelous thing about taking an extremely complicated software environment like FreeBSD, and then optimizing it for a particular use case, like FreeNAS, is that it isn't *designed* from the ground up to operate the way you would prefer, so sometimes you run into odd and unexplained things.
There are numerous things it might be trying to write to the disk, including some favorites of mine like massive atime updates, which can be triggered by something as seemingly harmless as a find|grep. We can wonder "why is this" all day long, but it really gets you nowhere. That's kind of why I hinted at something practical you could check to see if there's something obvious that can be isolated. That path leads to fixes.
