ChicagoBud
- Jun 21, 2016
Sort of leaving this for anyone else that has this issue and maybe for someone to check what I did. Specifically is it ok to have a smaller boot partition (100M) than what the gui now tries to create (260M)?
TL: DR: Recovery was a pain. GUI didn't work. Seems like FreeNAS may have changed the boot device partitioning scheme. Fix from the command line.
I'm on FreeNAS-11.1-RELEASE. So someone physically took (stole?) one of the two usb flash drives out of one of my freenas servers. Luckily(?) I had setup a mirror and the server hasn't stopped working. Unfortunately, I was having troubles recovering from this even though I had a spare flash drive that was the same size (so I thought) and brand that I was trying to replace the missing drive with.
The first issue I ran into was that even though the old drive was physically removed, it was still part of the freenas-boot pool. I tried to remove it from the pool via the gui and that failed with a python traceback which I did not save (sorry). Google indicated that I could detach it from the command line so I did that and old drive was gone from the GUI - yeah.
Then I was trying to attach the new disk to the boot pool. Doing that from the GUI, I was getting:
Humm, so turns out what is really happening is the drives are not exactly the same and perhaps there is a new partitioning scheme for boot devices:
For me, da16 is the original (good) device in the pool and da17 is the replacement:
The 2nd partition failed to get created as there wasn't enough space left on the disk due to the larger size of the 1st partition. I ended up deleting the first partition and recreating the partitions with:
basically matching the size of the partitions even though they don't start at the same place on the device. Then I attached the new device to the pool and updated the boot code in the first partition (I hope).
Hopefully this will be good even though partition 1 is smaller than the new default. I'd appreciate any feedback on this. -- Bud
[MiddlewareError: Command '('gpart', 'add', '-t', 'freebsd-zfs', '-i', '2', '-a', '4k', '-s', '31973138432B', 'da17')' returned non-zero exit status 1.]
root@storage03:~ # gpart show da16 da17 => 34 62652349 da16 GPT (30G) 34 204800 1 efi (100M) 204834 6 - free - (3.0K) 204840 62447536 2 freebsd-zfs (30G) 62652376 7 - free - (3.5K) => 40 62668720 da17 GPT (30G) 40 532480 1 efi (260M) 532520 62136240 - free - (30G)
gpart show da16 da17 gpart delete -i 1 da17 gpart add -b 40 -s 204800 -t efi da17 gpart add -t freebsd-zfs -s 62447536 da17
zpool attach freenas-boot /dev/da16p2 /dev/da17p2 gpart bootcode -b /boot/pmbr -p /boot/gptzfsboot -i 1 da17
