I am getting quite a lot of console messages like this:
I guess "-^A" is supposed to be an "ü" - are there issues with non ASCII characters now??
I don't know if this is the cause, but top also shows smbd at 100% CPU:
Feb 24 19:28:21 Schnigges-NAS smbd[28287]: [2014/02/24 19:28:21.674351, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle) Feb 24 19:28:21 Schnigges-NAS smbd[28287]: Conversion error: Incomplete multibyte sequence(M-^Anster (bis 12.2008))
last pid: 32550; load averages: 2.22, 1.93, 2.07 up 0+20:29:35 19:45:28 74 processes: 3 running, 71 sleeping CPU: 11.6% user, 0.0% nice, 37.4% system, 0.5% interrupt, 50.5% idle Mem: 212M Active, 546M Inact, 14G Wired, 144M Buf, 1096M Free ARC: 12G Total, 984M MFU, 10G MRU, 74M Anon, 122M Header, 1000M Other Swap: 12G Total, 12G Free PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 27552 root 2 103 0 312M 29476K CPU0 0 31:49 100.00% smbd 20389 root 1 22 0 29360K 3548K zio->i 2 1:59 2.29% rsync 20383 root 1 22 0 25264K 5240K CPU2 2 2:01 2.20% rsync 55429 921 3 20 0 114M 59940K select 2 1:58 1.86% transmission-daemon 32520 root 1 21 0 12976K 2572K select 0 0:00 1.07% rsync 32519 root 1 20 0 12976K 2616K select 2 0:00 0.78% rsync 20388 root 1 20 0 25264K 2868K select 2 0:43 0.29% rsync 20403 root 1 20 0 78512K 4280K select 0 0:45 0.20% rsync 20387 root 1 20 0 45744K 9124K select 2 1:46 0.00% rsync 20394 root 1 20 0 53936K 7416K select 0 1:25 0.00% rsync 5419 root 12 20 0 146M 21920K uwait 1 1:03 0.00% collectd 3612 root 6 20 0 363M 152M usem 2 0:42 0.00% python2.7 29359 972 14 35 15 245M 69100K select 1 0:03 0.00% python 8960 root 6 20 0 167M 29344K usem 3 0:02 0.00% python2.7 7979 root 6 20 0 154M 24232K usem 0 0:02 0.00% python2.7 9861 root 6 20 0 145M 19764K usem 0 0:02 0.00% python2.7 3208 root 1 20 0 22220K 3308K select 1 0:01 0.00% ntpd 28287 root 2 20 0 312M 27224K kqread 2 0:01 0.00% smbd 29344 972 14 20 0 205M 56900K uwait 3 0:01 0.00% Plex Media Server 51299 root 6 20 0 149M 19400K usem 2 0:01 0.00% python2.7 2899 root 1 20 0 12044K 1560K select 2 0:00 0.00% syslogd 5178 root 1 52 0 149M 11024K ttyin 3 0:00 0.00% python2.7 50973 root 4 52 0 160M 10572K select 1 0:00 0.00% python2.7 269 uucp 1 20 0 14232K 1840K WCTRL 2 0:00 0.00% usbhid-ups 29371 972 13 20 0 160M 29980K select 0 0:00 0.00% Plex DLNA Server 67852 root 1 20 0 271M 17316K select 0 0:00 0.00% smbd 98699 root 1 20 0 69524K 5408K select 2 0:00 0.00% sshd 27643 www 1 20 0 26044K 5252K kqread 2 0:00 0.00% nginx 5040 root 1 52 0 14136K 1720K nanslp 0 0:00 0.00% cron 20386 root 1 20 0 45744K 3216K select 1 0:00 0.00% rsync 28288 root 2 20 0 309M 19420K kqread 1 0:00 0.00% smbd 9675 root 1 20 0 14180K 1588K nanslp 2 0:00 0.00% cron 7788 root 1 20 0 14180K 1608K nanslp 2 0:00 0.00% cron 8773 root 1 20 0 14180K 1672K nanslp 0 0:00 0.00% cron 9621 root 1 20 0 12088K 1532K select 3 0:00 0.00% syslogd 271 uucp 1 20 0 20352K 3200K select 0 0:00 0.00% upsd 7720 root 1 20 0 12088K 1552K select 2 0:00 0.00% syslogd 8716 root 1 20 0 12088K 1616K select 3 0:00 0.00% syslogd 98701 root 1 20 0 17520K 3316K pause 1 0:00 0.00% csh
