Has someone got a suggestion to fix this :
I installed 9.2.1 on a new HP server. The 3 hard drives came from another FreeNAS server, the import into a UFS volume worked well and all the data and folders seemed to be ok. Set up shares and started CIFS. I started setting up permissions, users and groups to control access by the various users. Then deleted some unused jails. At this stage CIFS stopped running, it was not possible to switch it on again. I then reinstalled FreeNAS on the server, this wrote a new configuration file. I imported volumes again, and set up shares, but still CIFS will not start. Below is a portion of the console log that may be relevant :
Feb 16 12:38:54 freenas notifier: Starting nginx.
Feb 16 02:38:54 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord
0000000800C2FD60 freenas.local. (Addr) that's already in the list
0000000800C30180 16.0.12.10.in-addr.arpa. (PTR) that's already in the list
Feb 16 12:39:34 freenas notifier: Setting hostname: beneke16.rbd.co.za.
Feb 16 12:40:54 freenas notifier: Updating motd:.
Feb 16 12:40:54 freenas notifier: powerd not running?
Feb 16 12:40:54 freenas notifier: Starting powerd.
Feb 16 12:46:10 freenas notifier: You need to create a volume to proceed!
Feb 16 12:46:10 freenas notifier: Performing sanity check on Samba configuration: FAILED
Feb 16 12:53:34 freenas notifier: Mounting late file systems:.
Feb 16 12:53:34 freenas notifier: Stopping collectd.
Feb 16 12:53:39 freenas notifier: Waiting for PIDS: 3366.
Feb 16 12:53:39 freenas notifier: Starting collectd.
Feb 16 13:05:55 freenas generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/pdbedit -d 0
-i smbpasswd:/tmp/tmpWFF_9m -e tdbsam:/var/etc/private/passdb.tdb -s /usr/local/etc/smb4.conf
Feb 16 13:05:56 freenas notifier: winbindd not running? (check /var/run/samba/winbindd.pid).
Feb 16 13:05:56 freenas notifier: smbd not running? (check /var/run/samba/smbd.pid).
Feb 16 13:05:56 freenas notifier: nmbd not running? (check /var/run/samba/nmbd.pid).
It seems that the problem may be with pid for winbindd smbd and nmbd. The problem seems to be stored in the volume/directory structure that contains our data (that used to also contain the jails). Any suggestions please. I am not fluent in Unix/FreeBSD.
Thanks. Richard
Thanks. Richard
