Freenas 9.2.0 lock order reversal:
fishinfiend
I am good on computers, but don't have a clue on computer coding. I am working on setting up my shares and I ended up getting this.
Jan  1 09:56:20 HHDB newsyslog[1730]: logfile first created
Jan  1 09:56:20 HHDB syslogd: kernel boot file is /boot/kernel-debug/kernel
Jan  1 09:56:20 HHDB kernel:
Jan  1 09:56:20 HHDB kernel: Fatal trap 9: general protection fault while in kernel mode
Jan  1 09:56:20 HHDB kernel: cpuid = 1; apic id = 11
Jan  1 09:56:20 HHDB kernel: instruction pointer    = 0x20:0xffffffff80ba022b
Jan  1 09:56:20 HHDB kernel: stack pointer            = 0x28:0xffffff846817c420
Jan  1 09:56:20 HHDB kernel: frame pointer            = 0x28:0xffffff846817c4c0
Jan  1 09:56:20 HHDB kernel: code segment        = base 0x0, limit 0xfffff, type 0x1b
Jan  1 09:56:20 HHDB kernel: = DPL 0, pres 1, long 1, def32 0, gran 1
Jan  1 09:56:20 HHDB kernel: processor eflags    = interrupt enabled, resume, IOPL = 0
Jan  1 09:56:20 HHDB kernel: current process        = 68248 (python2.7)
Jan  1 09:56:20 HHDB kernel: lock order reversal:
Jan  1 09:56:20 HHDB kernel: 1st 0xffffffff814f14e0 pmap pv list (pmap pv list) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/amd64/amd64/pmap.c:3576
Jan  1 09:56:20 HHDB kernel: 2nd 0xffffff800075aee0 AHCI channel lock (AHCI channel lock) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/cam/cam_periph.h:192
Jan  1 09:56:20 HHDB kernel: KDB: stack backtrace:
Jan  1 09:56:20 HHDB kernel: Copyright (c) 1992-2013 The FreeBSD Project.
Jan  1 09:56:20 HHDB kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Jan  1 09:56:20 HHDB kernel: The Regents of the University of California. All rights reserved.
Jan  1 09:56:20 HHDB kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Jan  1 09:56:20 HHDB kernel: FreeBSD 9.2-RELEASE #0 r+2315ea3: Fri Dec 20 12:52:00 PST 2013
Jan  1 09:56:20 HHDB kernel: root@build.ixsystems.com:/tank/home/jkh/checkout/freenas/os-base/amd64/tank/home/jkh/checkout/freenas/FreeBSD/src/sys/FREENAS.amd64-DEBUG amd64
Jan  1 09:56:20 HHDB kernel: gcc version 4.2.1 20070831 patched [FreeBSD]
Jan  1 09:56:20 HHDB kernel: WARNING: WITNESS option enabled, expect reduced performance.
Jan  1 09:56:20 HHDB kernel: CPU: AMD A4-4000 APU with Radeon(tm) HD Graphics    (2994.61-MHz K8-class CPU)
Jan  1 09:56:20 HHDB kernel: Origin = "AuthenticAMD"  Id = 0x610f31  Family = 0x15  Model = 0x13  Stepping = 1
Jan  1 09:56:20 HHDB kernel: Features=0x178bfbff
Jan  1 09:56:20 HHDB kernel: Features2=0x3e98320b
Jan  1 09:56:20 HHDB kernel: AMD Features=0x2e500800
Jan  1 09:56:20 HHDB kernel: AMD Features2=0x1ebbfff,NodeId,TBM,Topology,,>
Jan  1 09:56:20 HHDB kernel: Standard Extended Features=0x8
Jan  1 09:56:20 HHDB kernel: TSC: P-state invariant, performance statistics
Jan  1 09:56:20 HHDB kernel: real memory  = 17179869184 (16384 MB)
Jan  1 09:56:20 HHDB kernel: avail memory = 15929389056 (15191 MB)
Jan  1 09:56:20 HHDB kernel: Event timer "LAPIC" quality 400
Jan  1 09:56:20 HHDB kernel: ACPI APIC Table:
Jan  1 09:56:20 HHDB kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Jan  1 09:56:20 HHDB kernel: FreeBSD/SMP: 1 package(s) x 2 core(s)
Jan  1 09:56:20 HHDB kernel: cpu0 (BSP): APIC ID: 16
Jan  1 09:56:20 HHDB kernel: cpu1 (AP): APIC ID: 17
Jan  1 09:56:20 HHDB kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Jan  1 09:56:20 HHDB kernel: ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20110527/tbfadt-586)
Jan  1 09:56:20 HHDB kernel: ioapic0  irqs 0-23 on motherboard
Jan  1 09:56:20 HHDB kernel: kbd1 at kbdmux0
Jan  1 09:56:20 HHDB kernel: cryptosoft0:  on motherboard
Jan  1 09:56:20 HHDB kernel: aesni0:  on motherboard
Jan  1 09:56:20 HHDB kernel: padlock0: No ACE support.
Jan  1 09:56:20 HHDB kernel: acpi0:  on motherboard
Jan  1 09:56:20 HHDB kernel: acpi0: Power Button (fixed)
Jan  1 09:56:20 HHDB kernel: cpu0:  on acpi0
Jan  1 09:56:20 HHDB kernel: cpu1:  on acpi0
Jan  1 09:56:20 HHDB kernel: attimer0:  port 0x40-0x43 irq 0 on acpi0
Jan  1 09:56:20 HHDB kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Jan  1 09:56:20 HHDB kernel: Event timer "i8254" frequency 1193182 Hz quality 100
Jan  1 09:56:20 HHDB kernel: atrtc0:  port 0x70-0x71 irq 8 on acpi0
Jan  1 09:56:20 HHDB kernel: Event timer "RTC" frequency 32768 Hz quality 0
Jan  1 09:56:20 HHDB kernel: hpet0:  iomem 0xfed00000-0xfed003ff on acpi0
Jan  1 09:56:20 HHDB kernel: Timecounter "HPET" frequency 14318180 Hz quality 950
Jan  1 09:56:20 HHDB kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Jan  1 09:56:20 HHDB kernel: acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Jan  1 09:56:20 HHDB kernel: pcib0:  port 0xcf8-0xcff on acpi0
Jan  1 09:56:20 HHDB kernel: pci0:  on pcib0
Jan  1 09:56:20 HHDB kernel: vgapci0:  port 0xf000-0xf0ff mem 0xc0000000-0xcfffffff,0xff700000-0xff73ffff irq 17 at device 1.0 on pci0
Jan  1 09:56:20 HHDB kernel: pci0:  at device 1.1 (no driver attached)
Jan  1 09:56:20 HHDB kernel: pci0:  at device 16.0 (no driver attached)
Jan  1 09:56:20 HHDB kernel: pci0:  at device 16.1 (no driver attached)
Jan  1 09:56:20 HHDB kernel: ahci0:  port 0xf190-0xf197,0xf180-0xf183,0xf170-0xf177,0xf160-0xf163,0xf150-0xf15f mem 0xff751000-0xff7517ff irq 19 at device 17.0 on pci0
Jan  1 09:56:20 HHDB kernel: ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported
Jan  1 09:56:20 HHDB kernel: ahcich0:  at channel 0 on ahci0
Jan  1 09:56:20 HHDB kernel: ahcich2:  at channel 2 on ahci0
Jan  1 09:56:20 HHDB kernel: ohci0:  mem 0xff750000-0xff750fff irq 18 at device 18.0 on pci0
Jan  1 09:56:20 HHDB kernel: usbus0 on ohci0
Jan  1 09:56:20 HHDB kernel: ehci0:  mem 0xff74f000-0xff74f0ff irq 17 at device 18.2 on pci0
Jan  1 09:56:20 HHDB kernel: usbus1: EHCI version 1.0
Jan  1 09:56:20 HHDB kernel: usbus1 on ehci0
Jan  1 09:56:20 HHDB kernel: ohci1:  mem 0xff74e000-0xff74efff irq 18 at device 19.0 on pci0
Jan  1 09:56:20 HHDB kernel: usbus2 on ohci1
Jan  1 09:56:20 HHDB kernel: ehci1:  mem 0xff74d000-0xff74d0ff irq 17 at device 19.2 on pci0
Jan  1 09:56:20 HHDB kernel: usbus3: EHCI version 1.0
Jan  1 09:56:20 HHDB kernel: usbus3 on ehci1
Jan  1 09:56:20 HHDB kernel: pci0:  at device 20.0 (no driver attached)
Jan  1 09:56:20 HHDB kernel: atapci0:  port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf100-0xf10f at device 20.1 on pci0
Jan  1 09:56:20 HHDB kernel: ata0:  at channel 0 on atapci0
Jan  1 09:56:20 HHDB kernel: ata1:  at channel 1 on atapci0
Jan  1 09:56:20 HHDB kernel: pci0:  at device 20.2 (no driver attached)
Jan  1 09:56:20 HHDB kernel: isab0:  at device 20.3 on pci0
Jan  1 09:56:20 HHDB kernel: isa0:  on isab0
Jan  1 09:56:20 HHDB kernel: pcib1:  at device 20.4 on pci0
Jan  1 09:56:20 HHDB kernel: pci1:  on pcib1
Jan  1 09:56:20 HHDB kernel: ohci2:  mem 0xff74c000-0xff74cfff irq 18 at device 20.5 on pci0
Jan  1 09:56:20 HHDB kernel: usbus4 on ohci2
Jan  1 09:56:20 HHDB kernel: pcib2:  at device 21.0 on pci0
Jan  1 09:56:20 HHDB kernel: pci2:  on pcib2
Jan  1 09:56:20 HHDB kernel: re0:  port 0xe000-0xe0ff mem 0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 16 at device 0.0 on pci2
Jan  1 09:56:20 HHDB kernel: re0: Using 1 MSI-X message
Jan  1 09:56:20 HHDB kernel: re0: Chip rev. 0x2c800000
Jan  1 09:56:20 HHDB kernel: re0: MAC rev. 0x00100000
Jan  1 09:56:20 HHDB kernel: miibus0:  on re0
Jan  1 09:56:20 HHDB kernel: rgephy0:  PHY 1 on miibus0
Jan  1 09:56:20 HHDB kernel: rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
Jan  1 09:56:20 HHDB kernel: re0: Ethernet address: bc:5f:f4:ac:7a:e4
Jan  1 09:56:20 HHDB kernel: acpi_button0:  on acpi0
Jan  1 09:56:20 HHDB kernel: sc0:  at flags 0x100 on isa0
Jan  1 09:56:20 HHDB kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Jan  1 09:56:20 HHDB kernel: vga0:  at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Jan  1 09:56:20 HHDB kernel: atkbdc0:  at port 0x60,0x64 on isa0
Jan  1 09:56:20 HHDB kernel: atkbd0:  irq 1 on atkbdc0
Jan  1 09:56:20 HHDB kernel: kbd0 at atkbd0
Jan  1 09:56:20 HHDB kernel: atkbd0: [GIANT-LOCKED]
Jan  1 09:56:20 HHDB kernel: ppc0: cannot reserve I/O port range
Jan  1 09:56:20 HHDB kernel: wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
Jan  1 09:56:20 HHDB kernel: acpi_throttle0:  on cpu0
Jan  1 09:56:20 HHDB kernel: hwpstate0:  on cpu0
Jan  1 09:56:20 HHDB kernel: acpi_throttle1:  on cpu1
Jan  1 09:56:20 HHDB kernel: acpi_throttle1: failed to attach P_CNT
Jan  1 09:56:20 HHDB kernel: device_attach: acpi_throttle1 attach returned 6
Jan  1 09:56:20 HHDB kernel: Timecounters tick every 1.000 msec
Jan  1 09:56:20 HHDB kernel: ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Jan  1 09:56:20 HHDB kernel: DUMMYNET 0xfffffe0007243dc0 with IPv6 initialized (100409)
Jan  1 09:56:20 HHDB kernel: load_dn_sched dn_sched QFQ loaded
Jan  1 09:56:20 HHDB kernel: load_dn_sched dn_sched RR loaded
Jan  1 09:56:20 HHDB kernel: load_dn_sched dn_sched WF2Q+ loaded
Jan  1 09:56:20 HHDB kernel: load_dn_sched dn_sched FIFO loaded
Jan  1 09:56:20 HHDB kernel: load_dn_sched dn_sched PRIO loaded
Jan  1 09:56:20 HHDB kernel: usbus0: 12Mbps Full Speed USB v1.0
Jan  1 09:56:20 HHDB kernel: usbus1: 480Mbps High Speed USB v2.0
Jan  1 09:56:20 HHDB kernel: usbus2: 12Mbps Full Speed USB v1.0
Jan  1 09:56:20 HHDB kernel: usbus3: 480Mbps High Speed USB v2.0
Jan  1 09:56:20 HHDB kernel: usbus4: 12Mbps Full Speed USB v1.0
Jan  1 09:56:20 HHDB kernel: ugen0.1:  at usbus0
Jan  1 09:56:20 HHDB kernel: uhub0:  on usbus0
Jan  1 09:56:20 HHDB kernel: ugen4.1:  at usbus4
Jan  1 09:56:20 HHDB kernel: uhub1:  on usbus4
Jan  1 09:56:20 HHDB kernel: ugen3.1:  at usbus3
Jan  1 09:56:20 HHDB kernel: uhub2:  on usbus3
Jan  1 09:56:20 HHDB kernel: ugen2.1:  at usbus2
Jan  1 09:56:20 HHDB kernel: uhub3:  on usbus2
Jan  1 09:56:20 HHDB kernel: ugen1.1:  at usbus1
Jan  1 09:56:20 HHDB kernel: uhub4:  on usbus1
Jan  1 09:56:20 HHDB kernel: uhub1: 2 ports with 2 removable, self powered
Jan  1 09:56:20 HHDB kernel: uhub0: 5 ports with 5 removable, self powered
Jan  1 09:56:20 HHDB kernel: uhub3: 5 ports with 5 removable, self powered
Jan  1 09:56:20 HHDB kernel: uhub2: 5 ports with 5 removable, self powered
Jan  1 09:56:20 HHDB kernel: uhub4: 5 ports with 5 removable, self powered
Jan  1 09:56:20 HHDB kernel: ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Jan  1 09:56:20 HHDB kernel: ada0:  ATA-9 SATA 3.x device
Jan  1 09:56:20 HHDB kernel: ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Jan  1 09:56:20 HHDB kernel: ada0: Command Queueing enabled
Jan  1 09:56:20 HHDB kernel: ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Jan  1 09:56:20 HHDB kernel: ada0: quirks=0x1<4K>
Jan  1 09:56:20 HHDB kernel: ada0: Previously was known as ad4
Jan  1 09:56:20 HHDB kernel: ada1 at ahcich2 bus 0 scbus1 target 0 lun 0
Jan  1 09:56:20 HHDB kernel: ada1:  ATA-9 SATA 3.x device
Jan  1 09:56:20 HHDB kernel: ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Jan  1 09:56:20 HHDB kernel: ada1: Command Queueing enabled
Jan  1 09:56:20 HHDB kernel: ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Jan  1 09:56:20 HHDB kernel: ada1: quirks=0x1<4K>
Jan  1 09:56:20 HHDB kernel: ada1: Previously was known as ad6
Jan  1 09:56:20 HHDB kernel: ada2 at ata0 bus 0 scbus2 target 0 lun 0
Jan  1 09:56:20 HHDB kernel: ada2:  ATA-9 SATA 3.x device
Jan  1 09:56:20 HHDB kernel: ada2: 33.300MB/s transfers (UDMA2, PIO 8192bytes)
Jan  1 09:56:20 HHDB kernel: ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Jan  1 09:56:20 HHDB kernel: ada2: quirks=0x1<4K>
Jan  1 09:56:20 HHDB kernel: ada2: Previously was known as ad0
Jan  1 09:56:20 HHDB kernel: SMP: AP CPU #1 Launched!
Jan  1 09:56:20 HHDB kernel: Timecounter "TSC-low" frequency 1497305849 Hz quality 1000
Jan  1 09:56:20 HHDB kernel: ugen2.2:  at usbus2
Jan  1 09:56:20 HHDB kernel: Root mount waiting for: usbus1
Jan  1 09:56:20 HHDB kernel: ugen1.2:  at usbus1
Jan  1 09:56:20 HHDB kernel: umass0:  on usbus1
Jan  1 09:56:20 HHDB kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
Jan  1 09:56:20 HHDB kernel: mountroot: waiting for device /dev/ufs/FreeNASs1a ...
Jan  1 09:56:20 HHDB kernel: da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
Jan  1 09:56:20 HHDB kernel: da0:  Removable Direct Access SCSI-5 device
Jan  1 09:56:20 HHDB kernel: da0: 40.000MB/s transfers
Jan  1 09:56:20 HHDB kernel: da0: 15267MB (31266816 512 byte sectors: 255H 63S/T 1946C)
Jan  1 09:56:20 HHDB kernel: da0: quirks=0x2
Jan  1 09:56:20 HHDB kernel: 1st 0xffffff83bc03c5f8 bufwait (bufwait) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_bio.c:3126
Jan  1 09:56:20 HHDB kernel: 2nd 0xfffffe000d24b000 dirhash (dirhash) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/ufs/ufs/ufs_dirhash.c:284
Jan  1 09:56:20 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff846801b180
Jan  1 09:56:20 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff846801b240
Jan  1 09:56:20 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff846801b260
Jan  1 09:56:20 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff846801b320
Jan  1 09:56:20 HHDB kernel: _sx_xlock() at _sx_xlock+0x64/frame 0xffffff846801b350
Jan  1 09:56:20 HHDB kernel: ufsdirhash_acquire() at ufsdirhash_acquire+0x44/frame 0xffffff846801b370
Jan  1 09:56:20 HHDB kernel: ufsdirhash_add() at ufsdirhash_add+0x19/frame 0xffffff846801b3a0
Jan  1 09:56:20 HHDB kernel: ufs_direnter() at ufs_direnter+0x97d/frame 0xffffff846801b470
Jan  1 09:56:20 HHDB kernel: ufs_makeinode() at ufs_makeinode+0x274/frame 0xffffff846801b630
Jan  1 09:56:20 HHDB kernel: VOP_CREATE_APV() at VOP_CREATE_APV+0x102/frame 0xffffff846801b660
Jan  1 09:56:20 HHDB kernel: vn_open_cred() at vn_open_cred+0x467/frame 0xffffff846801b7d0
Jan  1 09:56:20 HHDB kernel: kern_openat() at kern_openat+0x20a/frame 0xffffff846801b950
Jan  1 09:56:20 HHDB kernel: amd64_syscall() at amd64_syscall+0x2c8/frame 0xffffff846801ba70
Jan  1 09:56:20 HHDB kernel: Xfast_syscall() at Xfast_syscall+0xf7/frame 0xffffff846801ba70
Jan  1 09:56:20 HHDB kernel: --- syscall (5, FreeBSD ELF64, sys_open), rip = 0x800916c1c, rsp = 0x7fffffffdae8, rbp = 0 ---
Jan  1 09:56:20 HHDB kernel: 1st 0xfffffe000d2ad290 ufs (ufs) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_mount.c:1240
Jan  1 09:56:20 HHDB kernel: 2nd 0xfffffe000d2bbe60 devfs (devfs) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/ufs/ffs/ffs_vfsops.c:1414
Jan  1 09:56:20 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff846801b3d0
Jan  1 09:56:20 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff846801b490
Jan  1 09:56:20 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff846801b4b0
Jan  1 09:56:20 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff846801b570
Jan  1 09:56:20 HHDB kernel: __lockmgr_args() at __lockmgr_args+0x116a/frame 0xffffff846801b660
Jan  1 09:56:20 HHDB kernel: vop_stdlock() at vop_stdlock+0x39/frame 0xffffff846801b680
Jan  1 09:56:20 HHDB kernel: VOP_LOCK1_APV() at VOP_LOCK1_APV+0xe3/frame 0xffffff846801b6b0
Jan  1 09:56:20 HHDB kernel: _vn_lock() at _vn_lock+0x55/frame 0xffffff846801b710
Jan  1 09:56:20 HHDB kernel: ffs_flushfiles() at ffs_flushfiles+0xc5/frame 0xffffff846801b770
Jan  1 09:56:20 HHDB kernel: ffs_unmount() at ffs_unmount+0x75/frame 0xffffff846801b7d0
Jan  1 09:56:20 HHDB kernel: dounmount() at dounmount+0x368/frame 0xffffff846801b850
Jan  1 09:56:20 HHDB kernel: sys_unmount() at sys_unmount+0x3ce/frame 0xffffff846801b950
Jan  1 09:56:20 HHDB kernel: --- syscall (22, FreeBSD ELF64, sys_unmount), rip = 0x80087f32c, rsp = 0x7fffffffd528, rbp = 0x800c07eb0 ---
Jan  1 09:56:20 HHDB kernel: WARNING: /data was not properly dismounted
Jan  1 09:56:20 HHDB kernel: GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
Jan  1 09:56:20 HHDB kernel: 1st 0xfffffe000dbb0680 ufs (ufs) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_subr.c:2225
Jan  1 09:56:20 HHDB kernel: 2nd 0xffffff83bc20c540 bufwait (bufwait) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/ufs/ffs/ffs_vnops.c:261
Jan  1 09:56:20 HHDB kernel: 3rd 0xfffffe000db7fc68 ufs (ufs) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_subr.c:2225
Jan  1 09:56:20 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff8468039120
Jan  1 09:56:20 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff84680391e0
Jan  1 09:56:20 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff8468039200
Jan  1 09:56:20 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff84680392c0
Jan  1 09:56:20 HHDB kernel: __lockmgr_args() at __lockmgr_args+0x116a/frame 0xffffff84680393b0
Jan  1 09:56:20 HHDB kernel: ffs_lock() at ffs_lock+0x9c/frame 0xffffff8468039400
Jan  1 09:56:20 HHDB kernel: VOP_LOCK1_APV() at VOP_LOCK1_APV+0xe3/frame 0xffffff8468039430
Jan  1 09:56:20 HHDB kernel: _vn_lock() at _vn_lock+0x55/frame 0xffffff8468039490
Jan  1 09:56:20 HHDB kernel: vget() at vget+0x7b/frame 0xffffff84680394e0
Jan  1 09:56:20 HHDB kernel: vfs_hash_get() at vfs_hash_get+0xd5/frame 0xffffff8468039530
Jan  1 09:56:20 HHDB kernel: ffs_vgetf() at ffs_vgetf+0x48/frame 0xffffff84680395b0
Jan  1 09:56:20 HHDB kernel: softdep_sync_buf() at softdep_sync_buf+0x5cb/frame 0xffffff8468039690
Jan  1 09:56:20 HHDB kernel: ffs_syncvnode() at ffs_syncvnode+0x301/frame 0xffffff8468039710
Jan  1 09:56:20 HHDB kernel: ffs_sync() at ffs_sync+0x1b0/frame 0xffffff84680397d0
Jan  1 09:56:20 HHDB kernel: dounmount() at dounmount+0x33a/frame 0xffffff8468039850
Jan  1 09:56:20 HHDB kernel: sys_unmount() at sys_unmount+0x3ce/frame 0xffffff8468039950
Jan  1 09:56:20 HHDB kernel: amd64_syscall() at amd64_syscall+0x2c8/frame 0xffffff8468039a70
Jan  1 09:56:20 HHDB kernel: Xfast_syscall() at Xfast_syscall+0xf7/frame 0xffffff8468039a70
Jan  1 09:56:20 HHDB kernel: --- syscall (22, FreeBSD ELF64, sys_unmount), rip = 0x80087f32c, rsp = 0x7fffffffd528, rbp = 0x800c08438 ---
Jan  1 09:56:20 HHDB kernel: ZFS filesystem version: 5
Jan  1 09:56:20 HHDB kernel: ZFS storage pool version: features support (5000)
Jan  1 09:56:20 HHDB kernel: GEOM_ELI: Device ada0p1.eli created.
Jan  1 09:56:20 HHDB kernel: GEOM_ELI: Encryption: AES-XTS 256
Jan  1 09:56:20 HHDB kernel: GEOM_ELI:    Crypto: hardware
Jan  1 09:56:20 HHDB kernel: GEOM_ELI: Device ada1p1.eli created.
Jan  1 09:56:20 HHDB kernel: GEOM_ELI: Device ada2p1.eli created.
Jan  1 09:56:20 HHDB root: /etc/rc: WARNING: failed to start watchdogd
Jan  1 09:56:21 HHDB root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Jan  1 09:56:21 HHDB ntpd[1932]: ntpd 4.2.4p5-a (1)
Jan  1 09:56:21 HHDB root: Unknown USB device: vendor 0x0764 product 0x0501 bus uhub3
Jan  1 09:56:22 HHDB kernel: ........................+++
Jan  1 09:56:28 HHDB avahi-daemon[2716]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jan  1 09:56:30 HHDB kernel: 5
Jan  1 09:56:29 HHDB ntpd[1933]: time reset -1.312524 s
Jan  1 09:56:30 HHDB kernel: done.
Jan  1 09:56:45 HHDB kernel: lock order reversal:
Jan  1 09:56:45 HHDB kernel: 1st 0xfffffe000d6a0290 syncer (syncer) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_subr.c:1825
Jan  1 09:56:45 HHDB kernel: 2nd 0xfffffe0055937098 ufs (ufs) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/kern/vfs_subr.c:2225
Jan  1 09:56:45 HHDB kernel: KDB: stack backtrace:
Jan  1 09:56:45 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff84431734b0
Jan  1 09:56:45 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff8443173570
Jan  1 09:56:45 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff8443173590
Jan  1 09:56:45 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff8443173650
Jan  1 09:56:45 HHDB kernel: __lockmgr_args() at __lockmgr_args+0x116a/frame 0xffffff8443173740
Jan  1 09:56:45 HHDB kernel: ffs_lock() at ffs_lock+0x9c/frame 0xffffff8443173790
Jan  1 09:56:45 HHDB kernel: VOP_LOCK1_APV() at VOP_LOCK1_APV+0xe3/frame 0xffffff84431737c0
Jan  1 09:56:45 HHDB kernel: _vn_lock() at _vn_lock+0x55/frame 0xffffff8443173820
Jan  1 09:56:45 HHDB kernel: vget() at vget+0x7b/frame 0xffffff8443173870
Jan  1 09:56:45 HHDB kernel: vfs_msync() at vfs_msync+0x72/frame 0xffffff84431738d0
Jan  1 09:56:45 HHDB kernel: sync_fsync() at sync_fsync+0x10d/frame 0xffffff8443173900
Jan  1 09:56:45 HHDB kernel: VOP_FSYNC_APV() at VOP_FSYNC_APV+0x105/frame 0xffffff8443173930
Jan  1 09:56:45 HHDB kernel: sync_vnode() at sync_vnode+0x157/frame 0xffffff84431739b0
Jan  1 09:56:45 HHDB kernel: sched_sync() at sched_sync+0x1c8/frame 0xffffff8443173a20
Jan  1 09:56:45 HHDB kernel: fork_exit() at fork_exit+0x139/frame 0xffffff8443173a70
Jan  1 09:56:45 HHDB kernel: fork_trampoline() at fork_trampoline+0xe/frame 0xffffff8443173a70
Jan  1 09:56:45 HHDB kernel: --- trap 0, rip = 0, rsp = 0xffffff8443173b30, rbp = 0 ---
Jan  1 09:58:25 HHDB kernel: lock order reversal:
Jan  1 09:58:25 HHDB kernel: 1st 0xfffffe0009500400 if_addr_mtx (if_addr_mtx) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/netinet/igmp.c:1711
Jan  1 09:58:25 HHDB kernel: 2nd 0xffffffff814c5180 ifnet_rw (ifnet_rw) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/net/if.c:238
Jan  1 09:58:25 HHDB kernel: KDB: stack backtrace:
Jan  1 09:58:25 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff800027c440
Jan  1 09:58:25 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff800027c500
Jan  1 09:58:25 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff800027c520
Jan  1 09:58:25 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff800027c5e0
Jan  1 09:58:25 HHDB kernel: _rw_rlock() at _rw_rlock+0x8a/frame 0xffffff800027c660
Jan  1 09:58:25 HHDB kernel: ifnet_byindex() at ifnet_byindex+0x23/frame 0xffffff800027c680
Jan  1 09:58:25 HHDB kernel: igmp_intr() at igmp_intr+0x89/frame 0xffffff800027c710
Jan  1 09:58:25 HHDB kernel: netisr_dispatch_src() at netisr_dispatch_src+0x152/frame 0xffffff800027c770
Jan  1 09:58:25 HHDB kernel: igmp_v1v2_queue_report() at igmp_v1v2_queue_report+0x17a/frame 0xffffff800027c7c0
Jan  1 09:58:25 HHDB kernel: igmp_fasttimo() at igmp_fasttimo+0x8cf/frame 0xffffff800027c8c0
Jan  1 09:58:25 HHDB kernel: pffasttimo() at pffasttimo+0x2e/frame 0xffffff800027c8f0
Jan  1 09:58:25 HHDB kernel: softclock_call_cc() at softclock_call_cc+0x133/frame 0xffffff800027c980
Jan  1 09:58:25 HHDB kernel: softclock() at softclock+0x4a/frame 0xffffff800027c9a0
Jan  1 09:58:25 HHDB kernel: intr_event_execute_handlers() at intr_event_execute_handlers+0x6a/frame 0xffffff800027c9d0
Jan  1 09:58:25 HHDB kernel: ithread_loop() at ithread_loop+0x9b/frame 0xffffff800027ca20
Jan  1 09:58:25 HHDB kernel: fork_exit() at fork_exit+0x139/frame 0xffffff800027ca70
Jan  1 09:58:25 HHDB kernel: fork_trampoline() at fork_trampoline+0xe/frame 0xffffff800027ca70
Jan  1 09:58:25 HHDB kernel: --- trap 0, rip = 0, rsp = 0xffffff800027cb30, rbp = 0 ---
Jan  1 09:58:25 HHDB kernel: 2nd 0xffffff8000756218 re0 (network driver) @ /tank/home/jkh/checkout/freenas/FreeBSD/src/sys/dev/re/if_re.c:2886
Jan  1 09:58:25 HHDB kernel: db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff800027c2c0
Jan  1 09:58:25 HHDB kernel: kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff800027c380
Jan  1 09:58:25 HHDB kernel: _witness_debugger() at _witness_debugger+0x2c/frame 0xffffff800027c3a0
Jan  1 09:58:25 HHDB kernel: witness_checkorder() at witness_checkorder+0x875/frame 0xffffff800027c460
Jan  1 09:58:25 HHDB kernel: __mtx_lock_flags() at __mtx_lock_flags+0x95/frame 0xffffff800027c4a0
Jan  1 09:58:25 HHDB kernel: re_start() at re_start+0x34/frame 0xffffff800027c4c0
Jan  1 09:58:25 HHDB kernel: if_transmit() at if_transmit+0xd6/frame 0xffffff800027c500
Jan  1 09:58:25 HHDB kernel: ether_output_frame() at ether_output_frame+0x47/frame 0xffffff800027c520
Jan  1 09:58:25 HHDB kernel: ether_output() at ether_output+0x54a/frame 0xffffff800027c5a0
Jan  1 09:58:25 HHDB kernel: ip_output() at ip_output+0xd69/frame 0xffffff800027c680
Jan  1 09:58:25 HHDB kernel: igmp_intr() at igmp_intr+0x2a4/frame 0xffffff800027c710
I was working on getting my shares to work and then all of a sudden the web GUI and the Network location froze up. I walked over to the system and turned on the monitor I had this up. I reset the webpage and it fired up with this in the black box at the bottom of the screen.
So I am wondering what is it and what does it mean? IS it a bug?
My system is:
CPU
AMD A4-4000
Motherboard
Asrock FM2A85X-ITX
RAM
Corsar XMS 2 x 8GB 1333MHz
Hard Drive
WD Red 2TB x3
OS Hard Drive
Sandisk Fit 16GB
OS
FreeNAS
Case
Fractal Design Node 304
Power
Rosewill Capstone-450
Network Connection
DLink DAP-1522
gpsguy
Active Member
Go to memtest.org and download memtest+. Run at least 3 full tests.
