Freenas 9.1 RC2 network bind error
tanik1
I think there is a bug by loading a config file that was saved earlier.
I installed 9.1 and made some changes and installed 1 jail. then i saved my configs.
This evening something happened to my usb where it wouldn't read. I installed a fresh 9.1 on another usb and pluged it in and reload my configs. But it had issue where the screen was showing syserr trying to bind some address. I've check network settings and seems to be ok. so i rebooted and was still showing the same thing but i was able to login and do everything normally.
In the end i had to remove my jail that the config files saved. and rebooted and now i do not see any errors. I thinking there is some issue with reloading a config that has jailed installed prior.
tanik1
yea i shot myself on this one. I forgot to even think of getting logs. But I will be uploading my configs again. so this time I'll make sure that i get that error message.
tanik1
ok so this is what I'm getting relating to the bind issue with jail. And I have to just go back to the jail and go to the edit portion and just click save and it stops looking this message.
bit_1 sm-mta[3212]: daemon Daemon0: problem creating smtp socket
NOQUEUE: SYSERR(root): opendaemonsocket: daemon Daemon0: cannot bind: Can't assign requested address
Now i look at it. I think it could be some permission issue?
William Grzybowski
Thats just a bug in the jail subsystem, the sendmail is running and there is no address in lo0, you can just disable all sendmail daemons in the jail /etc/rc.conf.
It is pure cosmetic, no real issue there.
