freenas 9.1.1 jail storage problem
tanik1
Hello, I did a search but I couldn't find anything on the forums about this.
I just did an update to from 9.1 to 9.1.1. Everything seems to be fine. but in my jail section I am missing the storage tab to view my mounted storage. Is this a known issue with 9.1.1 ?
Mgmarceau
Same problem here, althought i've upgraded from 8.3.1 to 9.1.1 and I can't find the storage tab under the JAILS section.
Mgmarceau
It's only when you post something that you actually find your answer all by yourself after ... :)
In the directory tree (left of your screen):
-Select JAILS
-I've installed my minidlna and it had created a "customplugin_1" jail. Click on that jail.
-See the storage option? click on that.
-then you'll see "add storage"
Voila :)
tanik1
-Select JAILS
Voila :)
yea, but once you add the storage the way you do it, you dont see a list of what was added. there is no view like before where you can see what storage was added or mounted. its like adding blindly. as was like before there was a storage tab under the jails tab.
Yatti420
I was going to post about this.. It does look like it's changed.. I did like the previous look.. It does work though.. In the jails tab I simply clicked on my new pluginjail and hit add storage.. Worked normally..
Mgmarceau
Agreed Tanik1. For me, the only way I can view this right now is in the Jails > "jail name" in my case customplugin_1 > storage > various storage was created here.
It works tho right? If it doesn't, I can probably explain more :) Cheers!
tanik1
ok yea i found what you are saying. i forgot about the left navigation. So now i do see the storage that were mounted. i think this will work out ok. thanks.
D
dlavigne
Guest
That was actually a bug in 9.1.0. That tab showed, but did not work.
D
dlavigne
Guest
There currently isn't a way to do that in the GUI. If you'd like to have that functionality added, create a feature request at bugs.freenas.org and post the issue number here.
