I'm evaluating both openfiler and FreeNAS for internal backup media duties.
I have no idea if this is a FreeNAS issue or globalSAN initiator issue but I cannot authenticate using the globalSAN initiator to FreeNAS iSCSI. If I set CHAP to None, everything works fine.
If I enable CHAP, FreeNAS logs:
Aug 31 23:15:24 freenas istgt[28967]: istgt_iscsi.c:1603:istgt_iscsi_auth_params: ***ERROR*** auth failed (user itw)
Aug 31 23:15:24 freenas istgt[28967]: istgt_iscsi.c:2360:istgt_iscsi_op_login: ***ERROR*** iscsi_auth_params() failed
FreeNAS seems to require Always send "Session Type" so I have that enabled. Always send "AuthMethod" setting makes no difference set either on or off.
It gives identical error logging if Mutual CHAP is enabled.
To check that I had things configured correctly, I created a ubuntu 10.04 VM initiator and everything worked great.
