FreeNAS 8.3 Will Not retain ZFS Pool
ghostlobster
OK...I'm going nuts here. I have a 4x1TB RAID z1 array that was running on a 32 bit 8.2. I built another machine running 64 bit 8.3. On first boot, I auto-imported the ZFS volume, all datasets imported just fine. Like an idiot, however, I did a zpool upgrade, so there's no going back.
Upon a reboot of the box, the volume went away!!!! I rebooted, and there was no volume there. At this point, I said the hell with it and just did a reinstall of FreeNAS 8.3, not an upgrade install, but a regular install. Upon reinstall, I did an auto import again. The raid ID comes up, I select auto import, and it returns an error saying that it could not import the volume. Not too informative, and there are no volumes listed in the GUI, but if I go into a shell, and do a zpool status, I get the following:
pool: RAID
state: ONLINE
status: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the entire pool from backup.
see: http://www.sun.com/msg/ZFS-8000-8A
scan: none requested
NAME STATE READ WRITE CKSUM
RAID ONLINE 0 0 1
raidz1-0 ONLINE 0 0 2
gptid/32ea520c-031e-11e2-b182-000acd1fbb8d ONLINE 0 0 0
gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d ONLINE 0 0 0
gptid/36a53dae-031e-11e2-b182-000acd1fbb8d ONLINE 0 0 0
gptid/29ace990-0420-11e2-ba6f-000acd1fbb8d ONLINE 0 0
Now, upon another reboot, the ZFS volume is still gone, and now a zpool status says no pools available. So, tried autoimport again, same issue. Error: could not import ZFS Volume, even though the ZFS volume appears in the auto import field. Now, I'm OK if there was some data corruption on one of the drives, but all 4 of them? I'm not buying that for a minute. I'm using RAID z1 with 4 drives to protect against a single drive failure bringing the system down. Can anyone please help?
Here are the system properties:
Hostname freenas.local
Build FreeNAS-8.3.0-BETA3-x64 (r12468M)
Platform AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
Memory 4080MB
System Time Fri Oct 12 05:37:57 PDT 2012
Uptime 5:37AM up 3 mins, 0 users
Load Average 0.24, 0.34, 0.16
Connected through 192.168.2.179
I know, I should NEVER have upgraded the ZFS volume to 28 before backing things up, my bad. I need the data on this, though. Can anyone point me in some direction here?
Thanks!
***Edit***
A gpart show shows the following:
=> 63 390721905 ada0 MBR (186G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 386816976 - free - (184G)
=> 34 1953525101 ada1 GPT (931G)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 1949330703 2 freebsd-zfs (929G)
=> 34 1953525101 ada2 GPT (931G)
=> 0 1930257 ada0s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M)
=> 34 1953525101 ada3 GPT (931G)
=> 34 1953525101 ada4 GPT (931G)
Any ideas?? Basically, the volume does not exist in the GUI. I even tried a zpool import -f RAID, and that returns the following:
cannot import 'RAID': one or more devices is currently unavailable
ghostlobster
Update.
It appears that things are spiriling now. Within the GUI, if I select Auto Import Volume, the volume RAID with the identifying number is there and selectable. I then click on Import and get the following:
Select a valid choice. RAID is not one of the available choices
Then, selecting Import again generates the following:
Request Method: POST
Request URL: http://freenas/storage/auto-import/
Software Version: FreeNAS-8.3.0-BETA3-x64 (r12468M)
Exception Type: KeyError
Exception Value:
'volume_disks'
Exception Location: /usr/local/www/freenasUI/../freenasUI/storage/forms.py in clean, line 577
Server time: Fri, 12 Oct 2012 08:51:17 -0700
Traceback
Request information
GET
No GET data
POST
Variable Value
volume_disks u''
FILES
No FILES data
COOKIES
Variable Value
csrftoken '3624132558689a42ffc2231c37055a0b'
fntreeSaveSelectedCookie 'root%2F123'
sessionid '118c3bd7675f8593739ebaff80ed421b'
fntreeSaveStateCookie 'root%2Croot%2F111%2Croot%2F111%2F143%2F144%2F145%2Croot%2F111%2F143%2F144%2Croot%2F97%2Croot%2F110%2Croot%2F111%2F143%2Croot%2F104%2Croot%2F104%2F136%2F137%2Croot%2F104%2F136%2F137%2F138%2Croot%2F14%2Croot%2F102%2Croot%2F102%2F141%2Croot%2F102%2F141%2F143%2Croot%2F1%2F8%2Croot%2F89%2Croot%2F89%2F121%2Croot%2F89%2F121%2F122%2Croot%2F89%2F121%2F122%2F123%2Croot%2F104%2F136%2Croot%2F125%2Croot%2F125%2F157%2Croot%2F125%2F157%2F158%2Croot%2F125%2F157%2F158%2F159%2Croot%2F16%2Croot%2F48%2Croot%2F64%2F71%2Croot%2F107%2Croot%2F48%2F61%2Croot%2F64%2Croot%2F113%2Croot%2F113%2F145%2Croot%2F113%2F145%2F146%2Croot%2F113%2F145%2F146%2F147%2Croot%2F114%2Croot%2F114%2F154%2Croot%2F114%2F154%2F156%2Croot%2F1%2Croot%2F115%2F155%2F157%2Croot%2F17%2F28%2Croot%2F115%2F155%2Croot%2F17%2Croot%2F17%2F42%2Croot%2F65%2Croot%2F65%2F72%2Croot%2F65%2F97%2Croot%2F119%2Croot%2F119%2F158%2Croot%2F119%2F158%2F160%2Croot%2F18%2F32%2Croot%2F18%2F22%2Croot%2F120%2Croot%2F120%2F160%2Croot%2F120%2F160%2F162%2Croot%2F121%2Croot%2F121%2F161%2Croot%2F121%2F161%2F163'
META
Variable Value
wsgi.multiprocess False
HTTP_REFERER 'http://freenas/'
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.2.2'
SCRIPT_NAME u''
HTTP_X_CSRFTOKEN '3624132558689a42ffc2231c37055a0b'
REQUEST_METHOD 'POST'
PATH_INFO u'/storage/auto-import/'
HTTP_ORIGIN 'http://freenas'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING ''
CONTENT_LENGTH '13'
HTTP_ACCEPT_CHARSET 'ISO-8859-1,utf-8;q=0.7,*;q=0.3'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.4 (KHTML, like Gecko) Chrome/22.0.1229.94 Safari/537.4'
HTTP_CONNECTION 'keep-alive'
HTTP_COOKIE 'sessionid=118c3bd7675f8593739ebaff80ed421b; csrftoken=3624132558689a42ffc2231c37055a0b; fntreeSaveStateCookie=root%2Croot%2F111%2Croot%2F111%2F143%2F144%2F145%2Croot%2F111%2F143%2F144%2Croot%2F97%2Croot%2F110%2Croot%2F111%2F143%2Croot%2F104%2Croot%2F104%2F136%2F137%2Croot%2F104%2F136%2F137%2F138%2Croot%2F14%2Croot%2F102%2Croot%2F102%2F141%2Croot%2F102%2F141%2F143%2Croot%2F1%2F8%2Croot%2F89%2Croot%2F89%2F121%2Croot%2F89%2F121%2F122%2Croot%2F89%2F121%2F122%2F123%2Croot%2F104%2F136%2Croot%2F125%2Croot%2F125%2F157%2Croot%2F125%2F157%2F158%2Croot%2F125%2F157%2F158%2F159%2Croot%2F16%2Croot%2F48%2Croot%2F64%2F71%2Croot%2F107%2Croot%2F48%2F61%2Croot%2F64%2Croot%2F113%2Croot%2F113%2F145%2Croot%2F113%2F145%2F146%2Croot%2F113%2F145%2F146%2F147%2Croot%2F114%2Croot%2F114%2F154%2Croot%2F114%2F154%2F156%2Croot%2F1%2Croot%2F115%2F155%2F157%2Croot%2F17%2F28%2Croot%2F115%2F155%2Croot%2F17%2Croot%2F17%2F42%2Croot%2F65%2Croot%2F65%2F72%2Croot%2F65%2F97%2Croot%2F119%2Croot%2F119%2F158%2Croot%2F119%2F158%2F160%2Croot%2F18%2F32%2Croot%2F18%2F22%2Croot%2F120%2Croot%2F120%2F160%2Croot%2F120%2F160%2F162%2Croot%2F121%2Croot%2F121%2F161%2Croot%2F121%2F161%2F163; fntreeSaveSelectedCookie=root%2F123'
SERVER_NAME 'localhost'
REMOTE_PORT '54624'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '192.168.2.179'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_CONTENT_LENGTH '13'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
DOCUMENT_URI '/storage/auto-import/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x808fca210>
HTTP_HOST 'freenas'
wsgi.multithread True
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
REQUEST_URI '/storage/auto-import/'
HTTP_ACCEPT '*/*'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x80b8ce810>
REMOTE_ADDR '192.168.2.122'
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.8'
CSRF_COOKIE '3624132558689a42ffc2231c37055a0b'
HTTP_ACCEPT_ENCODING 'gzip,deflate,sdch'
paleoN
From a SSH session as root paste the output of:
zpool status -v
glabel status
mount
Also, for each disk the SMART info:
smartctl -q noserial -a /dev/adaX
Throw the output inside of some [code][/code] tags as it will preserve the formatting and keep my eyes from crossing.
ghostlobster
Awesome...Here's the output:
Zpool Status:
[root@freenas ~]# zpool status -v
no pools available
Glabel status:
[root@freenas ~]# glabel status
                                      Name  Status  Components
                             ufs/FreeNASs3     N/A  ada0s3
                             ufs/FreeNASs4     N/A  ada0s4
gptid/36a53dae-031e-11e2-b182-000acd1fbb8d     N/A  ada1p2
gptid/29ace990-0420-11e2-ba6f-000acd1fbb8d     N/A  ada2p2
                            ufs/FreeNASs1a     N/A  ada0s1a
gptid/32ea520c-031e-11e2-b182-000acd1fbb8d     N/A  ada3p2
gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d     N/A  ada4p2
Smartctl on ada1
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family:     Seagate Barracuda (SATA 3Gb/s, 4K Sectors)
Device Model:     ST1000DM003-9YN162
Firmware Version: CC4B
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Fri Oct 12 10:18:29 2012 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  575) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp
ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
Conveyance self-test routine
SCT capabilities:              (0x3085) SCT Status supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   112   099   006    Pre-fail  Always       -
       50082792
  3 Spin_Up_Time            0x0003   096   096   000    Pre-fail  Always       -
       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -
       23
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -
       0
  7 Seek_Error_Rate         0x000f   069   060   030    Pre-fail  Always       -
       7697052
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -
       528
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -
       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -
       23
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -
       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -
       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -
       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -
       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -
       0
190 Airflow_Temperature_Cel 0x0022   066   049   045    Old_age   Always       -
       34 (Min/Max 34/35)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -
       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -
       7
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -
       2331
194 Temperature_Celsius     0x0022   034   051   000    Old_age   Always       -
       34 (0 25 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -
      0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -
       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -
       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -
       201859167945071
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -
       319783093042
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -
       74701738963
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Smartcrl on ada2
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST31000528AS
Firmware Version: CC46
Sector Size:      512 bytes logical/physical
ATA Version is:   8
Local Time is:    Fri Oct 12 10:22:10 2012 PDT
                                        been run.
data collection:                (  600) seconds.
ort.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 176) minutes.
SCT capabilities:              (0x103f) SCT Status supported.
                                        SCT Data Table supported.
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   104   099   006    Pre-fail  Always       -
       6489623
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -
       0
       82
       0
  7 Seek_Error_Rate         0x000f   064   060   030    Pre-fail  Always       -
       3112571
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -
       1022
       0
       41
       0
       0
       0
       0
       0
190 Airflow_Temperature_Cel 0x0022   068   048   045    Old_age   Always       -
       32 (Min/Max 32/34)
194 Temperature_Celsius     0x0022   032   052   000    Old_age   Always       -
       32 (0 23 0 0 0)
195 Hardware_ECC_Recovered  0x001a   025   011   000    Old_age   Always       -
       6489623
       0
       0
       0
       59197534241901
       1809558747
       1320392585
No Errors Logged
Smartctl on ada3:
Model Family:     Seagate Barracuda Green (Adv. Format)
Device Model:     ST1000DL002-9TT153
Firmware Version: CC32
ATA Version is:   8
Local Time is:    Fri Oct 12 10:24:08 2012 PDT
                                        been run.
data collection:                (  623) seconds.
ort.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 179) minutes.
SCT capabilities:              (0x30b7) SCT Status supported.
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   107   099   006    Pre-fail  Always       -
       12646400
  3 Spin_Up_Time            0x0003   092   092   000    Pre-fail  Always       -
       0
       579
       0
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -
       6105476
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -
       7317
       0
       567
       0
       0
       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -
       4295032834
       0
190 Airflow_Temperature_Cel 0x0022   067   053   045    Old_age   Always       -
       33 (Min/Max 33/34)
       0
       57
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -
       583
194 Temperature_Celsius     0x0022   033   047   000    Old_age   Always       -
       33 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   015   005   000    Old_age   Always       -
       12646400
       0
       0
199 UDMA_CRC_Error_Count    0x003e   200   196   000    Old_age   Always       -
       6
       252806070017208
       3043770502
       1618823421
No Errors Logged
Smartctl on ada4
Model Family:     Seagate Barracuda LP
Device Model:     ST31000520AS
ATA Version is:   8
Local Time is:    Fri Oct 12 10:25:39 2012 PDT
                                        been run.
ort.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 222) minutes.
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -
       22786052
       0
       190
       0
  7 Seek_Error_Rate         0x000f   073   060   030    Pre-fail  Always       -
       24935991
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -
       8242
       0
       95
183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -
       0
       0
       0
       0
190 Airflow_Temperature_Cel 0x0022   067   056   045    Old_age   Always       -
       33 (Min/Max 32/34)
194 Temperature_Celsius     0x0022   033   044   000    Old_age   Always       -
       33 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   029   029   000    Old_age   Always       -
       22786052
       0
       0
       20
       220155728634110
       355260447
       218183539
No Errors Logged
Thanks again!
ghostlobster
I've tried posting a reply 2 times, and each time, i get the success page, but then no post appears? What gives???
OK, each time I try and put the code tags in a post, it does not show up!???
Any ideas???
ghostlobster
Trying one more time:
zpool status:
no pools available
glabel starus:
Mount:
[root@freenas ~]# mount
/dev/ufs/FreeNASs1a on / (ufs, local, read-only)
devfs on /dev (devfs, local, multilabel)
/dev/md0 on /etc (ufs, local)
/dev/md1 on /mnt (ufs, local)
/dev/md2 on /var (ufs, local)
/dev/ufs/FreeNASs4 on /data (ufs, local, noatime, soft-updates)
Going to put the smartctl outputs in another post.
Stephens
This one appeared. Maybe you're making your posts too long. put each output in a separate message (you'll probably have to wait 2 minutes between each post) or host it on pastebin and link to it. something.
paleoN
It was flagged for moderation. Wait until a moderator approves it or you could post the output to pastebin or wherever.
ghostlobster
Thank you. Just frustrated here, and concerned about about 70 movie rips, and some work files on that ZFS volume.
joshg678
you forgot the mount command. Or is was lost of Copy/Paste
ghostlobster
Sorry...here!
[root@freenas ~]#
paleoN
193 Load_Cycle_Count is higher than it needs to be on ada1. Both ada3 & ada4 have issues. 199 UDMA_CRC_Error_Count is high for both drives, ada4 in particular. There are multiple possible causes, but junk SATA cables and "loose" SATA connections are common ones.
zpool import
No point as the pool isn't imported. Of course you would know that if you understood why I was asking for it. Also, convention is to limit the signature to 4 lines or less, thanks.
joshg678
Thanks for the tip, just making sure you got all the data you asked for.
Since you mentioned it, why were you asking for it?
paleoN
It wasn't clear to me how far along ghostlobster was with the import. It's possible to have the pool imported, but the datasets not mounted. In this case the pool isn't currently imported which also means it won't be mounted.
ghostlobster
Just swapped out all 4 SATA cables, and the UDMA CRC Error count remained exactly as it was on all 4 drives. This time, before doing anything in the GUI, I went to a CLI and tried a zpool import and received the following:
[root@freenas ~]# zpool import -f
   pool: RAID
  state: FAULTED
 status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
        The pool may be active on another system, but can be imported using
        the '-f' flag.
   see: http://www.sun.com/msg/ZFS-8000-5E
        RAID                      FAULTED  corrupted data
          raidz1-0                ONLINE
            4140409436293275748   UNAVAIL  corrupted data
            13949890047348135266  UNAVAIL  corrupted data
            12864383027183141833  UNAVAIL  corrupted data
          14728624880139133829    UNAVAIL  corrupted data
I find it really hard to handle all 4 drives showing as corrupted. is there anyway to clean these drives at all?
Additionally, would flakey power show this issue? I have no reason to believe that I am having PSu issues, but I've seen bad power cause some strangeness. Also, I've got one of the SATA power splitters providing power to 2 of the drives from one actual power connector. I'm going to shut down again and make certain that all power is on its own cable just to be certain.
In the mean time, any other ideas or suggestions?
***Edited. Nope, put each drive on its own power connector, still no go. exact same results and output.
Augh!!!
paleoN
   pool: RAID
  state: FAULTED
        the '-f' flag.
          raidz1-0                ONLINE
I did not and I am not requesting the -f. I was asking for what zpool import saw and not even importing the pool yet. You do realize you have a non-redundant pool, a 3 x disk raidz vdev & a single disk stripe vdev.
Agreed. You are doing this under FreeNAS-8.3.0-BETA3-x64 correct? I've read about this happening on earlier FreeBSD 8, I think, when the disks were "out of order". ZFS should simply retaste the disks in this case unless i.e. the hostid is different. I think it is the fact that the zpool cache file no longer matches reality. I believe an export/import will fix it.
Also, just to confirm, the output of:
zdb -l /dev/ada2p2
ghostlobster
Pal;eon,
Forst, thanks for all the help here. I really appreciate it.
About the -f flag, sorry about that, got over zealous. performing a zpool import does nothing. It just returns back to the command prompt:
[root@freenas ~]#
Here's the output from zdb -l /dev/ada2p2
LABEL 0
    version: 28
    state: 0
    txg: 192838
    pool_guid: 10036866808421506734
    hostid: 1362761028
    hostname: 'freenas.local'
    top_guid: 11941661085329332228
    guid: 13949890047348135266
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        asize: 2994157387776
        is_log: 0
        children[0]:
            type: 'disk'
            guid: 4140409436293275748
            path: '/dev/gptid/32ea520c-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/32ea520c-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            path: '/dev/gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
        children[2]:
            type: 'disk'
            guid: 12864383027183141833
            path: '/dev/gptid/36a53dae-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/36a53dae-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
You mean I set this up incorrectly for redundancy? I thought RAIDZ1 was a redundancy setup, like RAID5? I'm so clieless with this! Damn, OK, once I get things back on their feet here, then I can figure out how to get this how I want it...after backing everything up first, of course.
Oh, and yes, beta3 of x64 8.3.
paleoN
Yes, well it wouldn't as you already force imported the pool. ;)
Good, the labels on the stripe vdev appear fine. I thought they would be.
The problem is you have a raidz1 vdev and a single disk, i.e. RAID0, vdev. All the individual vdevs of a pool need to be redundant in order for the pool be redundant. As you said, we can deal with this once we're there.
Export the pool:
zpool export RAID
If needed, in this particular instance, you can add a -f to the export. Try without it first.
Then:
zpool import
With no arguments please.
