I am building a FreeNAS system (first time) on a Dell Precision 490. It has 8 x 2GB DDR2 for a total of 16GB. BIOS seeing all memory. FreeNAS shell "dmidecode -t memory" shows all the memory too. I looked through the BIOS and it doesn't appear to be reserving memory or anything. (Running latest BIOS) Please let me know if you have any ideas. Here is the output.
Last login: Sun Feb 9 00:55:17 on pts/1 FreeBSD 11.3-RELEASE-p5 (FreeNAS.amd64) #0 r325575+8ed1cd24b60(HEAD): Mon Jan 27 18:07:23 UTC 2020 FreeNAS (c) 2009-2020, The FreeNAS Development Team All rights reserved. FreeNAS is released under the modified BSD license. For more information, documentation, help or support, go here: http://freenas.org Welcome to FreeNAS Warning: settings changed through the CLI are not written to the configuration database and will be reset on reboot. root@freenas[~]# dmidecode -t memory # dmidecode 3.2 Scanning /dev/mem for entry point. SMBIOS 2.3 present. Handle 0x1000, DMI type 16, 15 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Single-bit ECC Maximum Capacity: 32 GB Error Information Handle: Not Provided Number Of Devices: 8 Handle 0x1100, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 1 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B2BB Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1101, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 2 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B29D Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1102, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 3 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B2BD Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1103, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 4 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B29C Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1104, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 5 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B2CE Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1105, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 6 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B2B0 Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1106, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 7 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C Serial Number: DF03B2CC Asset Tag: 010710 Part Number: 36HTF25672F667D1D3 Handle 0x1107, DMI type 17, 27 bytes Memory Device Array Handle: 0x1000 Error Information Handle: No Error Total Width: 72 bits Data Width: 64 bits Size: 2048 MB Form Factor: FB-DIMM Set: None Locator: DIMM 8 Bank Locator: Not Specified Type: DDR2 FB-DIMM Type Detail: Synchronous Speed: 667 MT/s Manufacturer: 802C80B3802C
