FreeNAS 11.3 upgrade removed a dataset
David, with all due respect, I've asked you four times to check this in post #11, #13, #15 and again in post #19. Your latest post invalidates my comments in post #17. There's been a lot of time wasted in between. You need to follow the instructions to the letter and not be distracted along the way. You have a permissions issue. Return to post #9.
David Henrickson
Hello Basil. I understand your frustration. I have also done what you have asked and told you that I have manually at the TOP level of all of the pools have gone in and stated "OPEN" for all datasets, recursively and including all child datasets. They are 100% open. This is the issue. Windows shows it as a "special" permission as FreeNAS is in charge of the permissions, not Windows, but within FreeNAS, EVERYTHING is now 100% open to all users all groups. Still....blank within Windows File Explorer. I have never seen this before. All other ones are fine and like I showed you, the data is still there. Just not visible AT ALL within Windows, even with "hidden files" set as "show." This is my predicament. This is why I have posted. This HAS to be a bug. Why I am wondering if I should just go back to 11.2 to see if I can RE-access the files in there. My issue with that, is I don't want to compound the current issue by doing that and actually risk losing the data that I know is fine on FreeNAS, just not accessible.
It's not a bug, there's nothing wrong with permissions in 11.3. Feel free to use a previous boot environment to see what it shows you if you're convinced there's a bug, I see no evidence of one.
If you can see the files at the CLI in the FreeNAS shell, they are there. Permissions changes may show them to you again (or not if they aren't done correctly), but nothing about permissions changes will remove the files, ever.
Can you please show the output from ls -l /mnt/HenriskconStorage/Media/TVShows
and
getfacl /mnt/HenriskconStorage/Media/TVShows
David Henrickson
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@FreeNAS[~]# ls -l /mnt/HenriskconStorage/Media/TVShows
ls: /mnt/HenriskconStorage/Media/TVShows: No such file or directory
root@FreeNAS[~]# ls -l /mnt/HenricksonStorage/Media/TVShows
total 173
drwxrwxrwx+ 2 root wheel 2 Apr 13 03:03 .grab
-rwxrwxrwx+ 1 root wheel 0 Mar 10 23:53 .windows
dr-xr-xr-x+ 3 root wheel 3 Oct 24 2019 .zfs
drwxrwx---+ 6 root wheel 6 Oct 24 2019 Aaahh!!! Real Monsters (1994)
drwxrwx---+ 5 root wheel 5 Oct 24 2019 Big Love (2006)
drwxrwx---+ 28 root wheel 28 Oct 24 2019 Bob Ross - The Joy of Painting
drwxrwx---+ 3 root wheel 3 Oct 24 2019 Ducktales (2017)
drwxrwx---+ 4 root wheel 4 Dec 1 22:00 Family Guy (1999)
drwxrwx---+ 4 root wheel 4 Oct 24 2019 Fraggle Rock
drwxrwx---+ 6 root wheel 6 Oct 24 2019 Glee (2009)
drwxrwx---+ 10 root wheel 10 Nov 3 15:20 Home Improvement (1991)
drwxrwx---+ 4 root wheel 4 Jan 2 21:00 Last Man Standing (2011)
drwxrwx---+ 5 root wheel 5 Oct 24 2019 Modern Family (2009)
drwxrwx---+ 2 root wheel 3 Jan 11 22:21 Paw Patrol (2018)
drwxrwx---+ 6 root wheel 6 Jan 13 23:43 Peppa Pig (2004)
drwxrwx---+ 5 root wheel 5 Nov 3 21:37 Rugrats (1991)
drwxrwx---+ 8 root wheel 8 Nov 12 07:00 The Best of The Joy of Painting (1983)
and now
root@FreeNAS[~]#
root@FreeNAS[~]# getfacl /mnt/HenricksonStorage/Media/TVShows
# file: /mnt/HenricksonStorage/Media/TVShows
# owner: root
# group: wheel
owner@:rwxpDdaARWcCos:fd-----:allow
group@:rwxpDdaARWcCos:fd-----:allow
everyone@:r
David Henrickson
Thank you all for your help. I know its frustrating helping people that are new to this...so hopefully, I can learn from you and pass this on to the newbies like me later on.
OK, sorry for the poor spelling... I see you corrected it.
The permissions are as you say all for root:wheel (unix) permissions.
In Windows, under a powershell window, what do you get from whoami (or have you specified the user in the drive mapping for s: )?
On the FreeNAS server, what does zfs list show?
Also, in the jail what do you get from running sysrc -a (iocage exec plex sysrc -a ... substitute plex for the name of your plex jail to run it from the host)
David Henrickson
On Windows, I map the drive as a "another user' and use the Root user with the primary password. This should give the system full and unlimited access this way and bypass user setup and permissions and whatnot, right?
on the zfs list, I'll paste below
root@FreeNAS[~]# zfs list
NAME USED AVAIL REFER MOUNTPOINT
HenricksonMedia 13.6T 38.0G 2.71M /mnt/HenricksonMedia
HenricksonMedia/Movies 13.6T 38.0G 13.5T /mnt/HenricksonMedia/Movies
HenricksonStorage 2.26T 4.54T 71.0G /mnt/HenricksonStorage
HenricksonStorage/.system 825M 4.54T 641M legacy
HenricksonStorage/.system/configs-1c36823397d74dbc9e7d4fbefe8b455e 128K 4.54T 128K legacy
HenricksonStorage/.system/configs-2272cbf872134cd4ab2b960f79d0a321 76.7M 4.54T 76.7M legacy
HenricksonStorage/.system/configs-55cbeffba0794e2da55e83d3da56be25 128K 4.54T 128K legacy
HenricksonStorage/.system/configs-aa972085e7d1466a9081d63fb61712e3 1.06M 4.54T 1.06M legacy
HenricksonStorage/.system/cores 3.07M 4.54T 3.07M legacy
HenricksonStorage/.system/rrd-1c36823397d74dbc9e7d4fbefe8b455e 14.7M 4.54T 14.7M legacy
HenricksonStorage/.system/rrd-2272cbf872134cd4ab2b960f79d0a321 58.2M 4.54T 58.2M legacy
HenricksonStorage/.system/rrd-55cbeffba0794e2da55e83d3da56be25 15.3M 4.54T 15.3M legacy
HenricksonStorage/.system/rrd-aa972085e7d1466a9081d63fb61712e3 128K 4.54T 128K legacy
HenricksonStorage/.system/samba4 1.04M 4.54T 692K legacy
HenricksonStorage/.system/syslog-1c36823397d74dbc9e7d4fbefe8b455e 262K 4.54T 262K legacy
HenricksonStorage/.system/syslog-2272cbf872134cd4ab2b960f79d0a321 11.9M 4.54T 11.9M legacy
HenricksonStorage/.system/syslog-55cbeffba0794e2da55e83d3da56be25 279K 4.54T 279K legacy
HenricksonStorage/.system/syslog-aa972085e7d1466a9081d63fb61712e3 128K 4.54T 128K legacy
HenricksonStorage/.system/webui 128K 4.54T 128K legacy
HenricksonStorage/Financial 67.6M 956M 67.6M /mnt/HenricksonStorage/Financial
HenricksonStorage/Media 1.82T 4.54T 631G /mnt/HenricksonStorage/Media
HenricksonStorage/Media/Movies 625G 4.54T 625G /mnt/HenricksonStorage/Media/Movies
HenricksonStorage/Media/Music 53.7G 4.54T 53.7G /mnt/HenricksonStorage/Media/Music
HenricksonStorage/Media/Pictures 128K 4.88G 128K /mnt/HenricksonStorage/Media/Pictures
HenricksonStorage/Media/TVShows 453G 4.54T 439G /mnt/HenricksonStorage/Media/TVShows
HenricksonStorage/Personal 36.7G 4.54T 326K /mnt/HenricksonStorage/Personal
HenricksonStorage/Personal/Alyse 18.6G 4.54T 18.6G /mnt/HenricksonStorage/Personal/Alyse
HenricksonStorage/Personal/DJ 18.1G 4.54T 18.1G /mnt/HenricksonStorage/Personal/DJ
HenricksonStorage/Pictures 65.8G 434G 65.8G /mnt/HenricksonStorage/Pictures
HenricksonStorage/Software 270G 4.54T 264G /mnt/HenricksonStorage/Software
HenricksonStorage/iocage 1.72G 4.54T 3.55M /mnt/HenricksonStorage/iocage
HenricksonStorage/iocage/download 272M 4.54T 128K /mnt/HenricksonStorage/iocage/download
HenricksonStorage/iocage/download/11.2-RELEASE 272M 4.54T 272M /mnt/HenricksonStorage/iocage/download/11.2-R ELEASE
HenricksonStorage/iocage/images 128K 4.54T 128K /mnt/HenricksonStorage/iocage/images
HenricksonStorage/iocage/jails 264M 4.54T 128K /mnt/HenricksonStorage/iocage/jails
HenricksonStorage/iocage/jails/plex 263M 4.54T 256K /mnt/HenricksonStorage/iocage/jails/plex
HenricksonStorage/iocage/jails/plex/root 263M 4.54T 1.05G /mnt/HenricksonStorage/iocage/jails/plex/root
HenricksonStorage/iocage/log 134K 4.54T 134K /mnt/HenricksonStorage/iocage/log
HenricksonStorage/iocage/releases 1.19G 4.54T 128K /mnt/HenricksonStorage/iocage/releases
HenricksonStorage/iocage/releases/11.2-RELEASE 1.19G 4.54T 128K /mnt/HenricksonStorage/iocage/releases/11.2-R ELEASE
HenricksonStorage/iocage/releases/11.2-RELEASE/root 1.19G 4.54T 1.16G /mnt/HenricksonStorage/iocage/releases/11.2-R ELEASE/root
HenricksonStorage/iocage/templates 128K 4.54T 128K /mnt/HenricksonStorage/iocage/templates
JailStorage 144G 302G 88K /mnt/JailStorage
JailStorage/iocage 144G 302G 6.77M /mnt/JailStorage/iocage
JailStorage/iocage/download 561M 302G 88K /mnt/JailStorage/iocage/download
JailStorage/iocage/download/11.2-RELEASE 272M 302G 272M /mnt/JailStorage/iocage/download/11.2-RELEASE
JailStorage/iocage/download/11.3-RELEASE 289M 302G 289M /mnt/JailStorage/iocage/download/11.3-RELEASE
JailStorage/iocage/images 88K 302G 88K /mnt/JailStorage/iocage/images
JailStorage/iocage/jails 141G 302G 88K /mnt/JailStorage/iocage/jails
JailStorage/iocage/jails/PlexPass 103G 302G 184K /mnt/JailStorage/iocage/jails/PlexPass
JailStorage/iocage/jails/PlexPass/root 103G 302G 53.3G /mnt/JailStorage/iocage/jails/PlexPass/root
JailStorage/iocage/jails/PlexTest 37.7G 302G 100K /mnt/JailStorage/iocage/jails/PlexTest
JailStorage/iocage/jails/PlexTest/root 37.7G 302G 27.6G /mnt/JailStorage/iocage/jails/PlexTest/root
JailStorage/iocage/log 116K 302G 116K /mnt/JailStorage/iocage/log
JailStorage/iocage/releases 2.02G 302G 88K /mnt/JailStorage/iocage/releases
JailStorage/iocage/releases/11.2-RELEASE 1004M 302G 88K /mnt/JailStorage/iocage/releases/11.2-RELEASE
JailStorage/iocage/releases/11.2-RELEASE/root 1004M 302G 998M /mnt/JailStorage/iocage/releases/11.2-RELEASE /root
JailStorage/iocage/releases/11.3-RELEASE 1.04G 302G 88K /mnt/JailStorage/iocage/releases/11.3-RELEASE
JailStorage/iocage/releases/11.3-RELEASE/root 1.04G 302G 1.04G /mnt/JailStorage/iocage/releases/11.3-RELEASE /root
JailStorage/iocage/templates 88K 302G 88K /mnt/JailStorage/iocage/templates
freenas-boot 6.49G 101G 64K none
freenas-boot/ROOT 6.46G 101G 29K none
freenas-boot/ROOT/11.2-U4.1 477K 101G 757M /
freenas-boot/ROOT/11.2-U5 487K 101G 757M /
freenas-boot/ROOT/11.2-U6 339K 101G 758M /
freenas-boot/ROOT/11.2-U7 336K 101G 758M /
freenas-boot/ROOT/11.2-U8 336K 101G 759M /
freenas-boot/ROOT/11.3-U1 238K 101G 1.00G /
freenas-boot/ROOT/11.3-U2 6.45G 101G 1.01G /
freenas-boot/ROOT/Initial-Install 1K 101G 760M legacy
freenas-boot/ROOT/default 324K 101G 760M legacy
root@FreeNAS[~]#
David Henrickson
Yorick
I created a video that walks through what I consider "best practice" for creating Windows shares in FreeNAS, how to configure simple ACLs, how to set up users, and the description has some notes on troubleshooting and samba logs. Maybe it's useful, you may be able to compare your setup and see relevant differences. https://youtu.be/9Xsgsap0wgQ
David Henrickson
@sretalla did you get my reports from above? I got Yoricks' best practice video, but that doesn't help my situation with what I have going on currently in that dataset. I will watch that later when I want to create a NEW dataset.
Yes, I see.
All the permissions are looking right/OK.
I'm guessing that you're set up on the share to use ACLs although none are defined...
Maybe as a test we should add an ACL entry on the share with "everyone" giving full permissions, just to prove that it's a permissions problem.
David Henrickson
THANK YOU! Yes, I knew this would be a major pain. I'm new....but I knew my permissions had to be somewhat correct on this. This is such a weird issue to have. How would you like me to do it? In FreeNAS? Windows has zero permissions itself to change anything in that dataset, so I would assume you want me to add something in FreeNAS
Under Sharing | Windows Shares (SMB)... to the right of your share, the 3 vertical dots, then Edit ACL.
Then Add ACL Item (button in the middle on the left).
Then on the right, edit the Who to be everyone@
Then change the permissions to Type, Basic and Full control.
Tick the Apply permissions recursively and save.
diedrichg
And be sure to select Inherit! I've had no-access issues despite all permissions set correctly, once I selected Inherit, everything worked as expected.
David Henrickson
Hello @sretalla , I have done that. It still just does not show up for me to view. Copy elsewhere. View. Anything. So......strange and depressing.
David Henrickson
Hello @sretalla and others that have helped me out on this. I have basically given up on it. RANDOMLY, after a reboot, the folder of information showed up. I QUICKLY offloaded ALL data in that dataset and then went into FreeNAS and deleted that dataset. I assume something was just wonky with this dataset. I created it with all of the others; however, this one just clearly didn't want to work. Since the new folders have the data, everything has been working smoothly with the videos. Every boot, they show up without fail and PLEX can see them. Still not sure what went awry with that, but as you know from the past conversations, it was setup right. I did prove that with the screenshots. Most def a bug; however, not reproducible on my system to date and no one else had the issues.
Thank you!
