Reece Johnson
- Dec 2, 2015
Hey Everyone,
I have a FreeNAS system (details in signature) that has been acting up on me. I had 11.2 installed on it and it was very stable, went months without a reboot. But after upgrading to 11.3 I've been having issues.
I host a combination of VMs (running on a separate ESXi box) and other storage (security camera footage, PC rsync backups, etc) all going to this FreeNAS system. It's been configured that way for years, so no changes there. But after the upgrade to 11.3, every 2-3 weeks or I'll find that all my VMs have locked up. I check the uptime on my FreeNAS box and sure enough, it'll be a couple hours. The first time I thought it was a fluke, but now it's happened 3 times. I check another box I have on the same UPS and that one will have an uptime of months, so I don't think it's a power issue. This most recently happened today. I started trying to go through the logs to get an idea of what happened. Here are some snippets:
/var/log/messages:
I haven't been able to find too much more in the logs besides that. I'm struggling to figure out what's going on, and could use some help.
The main thing I'm doing differently on this, compared to 11.2, is that I added my VM environment to be backed up to Backblaze B2. I've been using B2 with FreeNAS, but mainly with small files and non-VM data. I was waiting for 11.3 to back up my VMs so I could snapshot them, then exclude the delta VMDK's to prevent it from copying forever as the disk images updated.
As part of that, I did notice that some of them seemed to keep copying. I managed to save this log before it rebooted:
I looked this up, and apparently it's been observed with rclone on other environments, so I don't think this is a FreeNAS issue. I don't know if this could be contributing, but figured I would mention it if somehow I'm running into some issue related to that.
I appreciate any help. Not too sure what other information to provide, so I could definitely use some guidance.
/var/log/messages:
Feb 25 00:00:00 freenas syslog-ng[1161]: Configuration reload request received, reloading configuration; Feb 25 00:00:00 freenas syslog-ng[1161]: Configuration reload finished; Feb 26 00:00:00 freenas syslog-ng[1161]: Configuration reload request received, reloading configuration; Feb 26 00:00:00 freenas syslog-ng[1161]: Configuration reload finished; Feb 27 00:00:00 freenas syslog-ng[1161]: Configuration reload request received, reloading configuration; Feb 27 00:00:00 freenas syslog-ng[1161]: Configuration reload finished; Feb 27 11:13:27 freenas (pass2:mpr0:0:4:0): LOG SENSE. CDB: 4d 00 0d 00 00 00 00 00 40 00 length 64 SMID 511 Aborting command 0xfffffe0001258e90 Feb 27 11:13:27 freenas mpr0: Sending reset from mprsas_send_abort for target ID 4 Feb 27 11:13:27 freenas (pass0:mpr0:0:2:0): LOG SENSE. CDB: 4d 00 0d 00 00 00 00 00 40 00 length 64 SMID 288 Aborting command 0xfffffe0001244e00 Feb 27 11:13:27 freenas mpr0: Sending reset from mprsas_send_abort for target ID 2 Feb 27 11:13:27 freenas (pass3:mpr0:0:5:0): LOG SENSE. CDB: 4d 00 0d 00 00 00 00 00 40 00 length 64 SMID 922 Aborting command 0xfffffe000127dd60 Feb 27 11:13:27 freenas mpr0: Sending reset from mprsas_send_abort for target ID 5 Feb 27 11:13:27 freenas (pass1:mpr0:0:3:0): LOG SENSE. CDB: 4d 00 2f 00 00 00 00 00 40 00 length 64 SMID 662 Aborting command 0xfffffe00012667a0 Feb 27 11:13:27 freenas mpr0: Sending reset from mprsas_send_abort for target ID 3 Feb 27 11:13:28 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:28 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:28 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 18 60 66 38 00 00 30 00 Feb 27 11:13:28 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 18 60 66 30 00 00 30 00 Feb 27 11:13:28 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:28 freenas (da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:28 freenas (da1:mpr0:0:3:0): Retrying command Feb 27 11:13:28 freenas (da3:mpr0:0:5:0): Retrying command Feb 27 11:13:28 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:28 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:28 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:28 freenas (da2:mpr0:0:4:0): Retrying command Feb 27 11:13:29 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:29 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:29 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 18 60 66 38 00 00 30 00 Feb 27 11:13:29 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 18 60 66 30 00 00 30 00 Feb 27 11:13:29 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:29 freenas (da1:mpr0:0:3:0): Retrying command Feb 27 11:13:29 freenas mpr0: (da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:29 freenas (da3:mpr0:0:5:0): Retrying command Feb 27 11:13:29 freenas mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:29 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:29 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:29 freenas (da2:mpr0:0:4:0): Retrying command Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:30 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:30 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 18 60 66 38 00 00 30 00 Feb 27 11:13:30 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 18 60 66 30 00 00 30 00 Feb 27 11:13:30 freenas (da2:(da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas mpr0:0:(da3:mpr0:0:5:0): Retrying command Feb 27 11:13:30 freenas 4:0): Retrying command Feb 27 11:13:30 freenas (da1:mpr0:0:3:0): Retrying command Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:30 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:30 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 18 60 66 38 00 00 30 00 Feb 27 11:13:30 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:30 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 18 60 66 30 00 00 30 00 Feb 27 11:13:30 freenas (da1:(da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:30 freenas mpr0:0:(da3:mpr0:0:5:0): Retrying command Feb 27 11:13:30 freenas 3:0): Retrying command Feb 27 11:13:30 freenas (da2:mpr0:0:4:0): Retrying command Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 18 60 66 38 00 00 30 00 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 18 60 66 30 00 00 30 00 Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): Error 5, Retries exhausted Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): Error 5, Retries exhausted Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): Error 5, Retries exhausted Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas mpr0: (da3:mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:31 freenas mpr0:0:5:0): Retrying command Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): Retrying command Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): Retrying command Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 3 Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 4 Feb 27 11:13:31 freenas mpr0: mprsas_action_scsiio: Freezing devq for target ID 5 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00 Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da2:mpr0:0:4:0): Retrying command Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): READ(10). CDB: 28 00 6b 31 e4 30 00 00 08 00 Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da3:mpr0:0:5:0): Retrying command Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): CAM status: CAM subsystem is busy Feb 27 11:13:31 freenas (da1:mpr0:0:3:0): Retrying command Feb 27 11:21:43 freenas syslog-ng[1161]: syslog-ng starting up; version='3.23.1' Feb 27 11:21:43 freenas Copyright (c) 1992-2019 The FreeBSD Project. Feb 27 11:21:43 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 Feb 27 11:21:43 freenas The Regents of the University of California. All rights reserved. Feb 27 11:21:43 freenas FreeBSD is a registered trademark of The FreeBSD Foundation. Feb 27 11:21:43 freenas FreeBSD 11.3-RELEASE-p5 #0 r325575+8ed1cd24b60(HEAD): Mon Jan 27 18:07:23 UTC 2020
root@freenas:/var/tmp/middlewared/jobs # cat 4544.log | tail Errors: 0 Checks: 221 / 221, 100% Transferred: 95 / 114, 83% Elapsed time: 228h54m59.8s Transferring: * FMC/FMC-flat.vmdk:110% /250G, 372.582k/s, - * Apache/Apache-flat.vmdk:137% /200G, 348.867k/s, - * VIRL_1/VIRL_1-flat.vmdk:108% /250G, 370.296k/s, - * Windows 10 Pro/Windows 10 Pro_0-flat.vmdk: 75% /250G, 343.794k/s, 52h13m47s
